Display / Operator Interface Options?
Dave Matthews
I am developing a new product based on the Propeller. This product will require a lot of user interface and information display. I have experimented with the VGA output and TV output, not what I need ... I guess I'm looking for something similar to the digital SVGA and greater resolution that we have on our workstations for example. I can budget in an industrial computer/touchscreen system for the operator interface, but I wanted to make sure I wasn't missing a bet in that regard with the propeller.
Would you folks kindly bring me up to speed on the display capabilities of the native Propeller and any suggestions and any advice you care to share?
Dave KI4PSR
Dave KI4PSR
there's also vga_hires text driver (2-color character) and a new appnote about GUIs using it.
I think that's about the best you can do straight from the Prop...
See http://Mikronauts.com/morpheus
I have a new revision with some new features, it will be on the site later; as will the 800x480 driver for the 7" OEM LCD displays (and serial touch controllers) I also sell.
PM me if you would like to continue discussing this off-line.
http://www.cubloc.com/product/06_02.php .
Jeff T.
Mickster
Some of the demos output at resolutions and frame rates that may not work with all monitors.
I have an application that has been working well for a couple years now using a touchpanel that I've integrated into a vga monitor:
http://forums.parallax.com/showthread.php?101720-Bergquist-5-Wire-touchscreen-controller-driver&highlight=bergquist
I use the 1024x768 driver because I found it the best balance between resolution and resources...
Dave KI4PSR
Dave KI4PSR
Dave
Dave
