Look at the menu bar at the top of every Parallax forum webpage. There's a button labelled OBEX. It's the Propeller OBject Exchange. If you want to write your own PID routines, use the Wikipedia for information ... there's more than enough theory and examples to get started.
As long as you have some kind of propulsion that can steer and some way to mount photo sensors to detect a line on the floor, you could probably build a line following robot out of it. Your photos show the wheels and batteries for propulsion along with a platform for photo sensors. Whether this will "work fine" for a line following robot or not depends on the things you haven't shown or described.
The construction of the chassis is very nicely done. It looks like essentially all of it was made from a single sheet of metal, cut and folded with a few fasteners. Is it stiff enough where the motors and wheels are mounted? You might consider some kind of strap across the front as a stiffener where the motors and wheels are mounted.
For maximum speed, chassis geometry & sensor quantity location are critical, as is the software to control it. Here's one ridiculously fast demo for the 3pi robot: http://www.youtube.com/watch?v=mJV-KDqHgDQ You can see it accelerate to higher speeds in the longer straightaways. At those speeds, traction, weight and rotational mass make a huge difference.
The type of line (wide vs. narrow, curved vs straight + 90-degree turns, etc) is a factor worth considering for your robot's physical configuration.
I have checked the PM of motor it was not so fast with single of 4.2V....
that want i from 375RPM motor..!!
OK,Now come to hardware is there any requirement of connecting any buffer or not??
Because i am not using any H bridges...only transistor like BC547 or 588...
1) If you turn a motor on and off using a transistor, the amount of current drawn by the motor has to be less than the maximum allowed current for the transistor ... See the transistor's datasheet for the value. Remember that a motor can draw several times the "normal" current when the motor is under heavy mechanical load and the transistor has to chosen based on that.
2) A H-Bridge is used so the motor can be reversed. If you don't need the motor to run in reverse, you may not need an H-Bridge.
The Wikipedia is a very good resource. It has been translated into many languages as well. For example, there's a good section on H-Bridges.
I think there is no need to reverse the motor in line follower...??
And pls suggest any transistor and what should i do to isolate the uC..??
one more question i am using 4.2V cell , propeller board work on 3.3V i don't have any regulator below 7805 or 317 a variable one...
there are two supply on the board 4.4V near by and regulated 3.3V so where should i connect the 4.2V cell to Board, will to that opp. to GND pin on board ( 4.4V )??
"I think there is no need to reverse the motor in line follower ... ??" That's your choice. Having reversible motors allows more flexibility and the ability to make sharp turns with one motor going forward and the other in reverse.
Look at the Nuts and Volts Columns, in particular #6 which discusses the use of transistors to control small motors, relays, and solenoids. It was written for the Stamps, but the same ideas apply to the Propeller. The only difference is that the voltages on the microcontroller are 3.3V rather than 5V for the Stamps. Since bipolar transistors are current driven, you just have to change the base resistor values so that there's roughly the same amount of base current with the 3.3V of the Propeller. Use Ohm's Law.
You didn't say what board you're using. Assuming you're using a QuickStart Board, there are pins on J1 and J3 for Vin and Ground. That's where you should connect your 4.2V battery. Look at the QuickStart schematic which you can download from Parallax (here).
I have got L298 chip for h- bridges the problem is what the use of logic supply pin 9voltage??
Is that mean at what logic the bridges will work If yes then i have connected to 5V..
and current sensing pin 1 to GND without any resistance...
Out put 1 and 2 to motor terminal just for testing small motor pin 2 and 3...
and input spin to GND and Vcc for testing pin 5 and 7...
till now i am not using output 3 and 4....
supply voltage is 12V 800mA max.
edited: the problem is the motor is not rotating...
I looked at the L298 datasheet, watch out for "Vss" which is used for "Logic Supply Voltage" (4.5V to 7.0V). I think it's very strange they use Vss that way.
I'm not sure if 3.3V will be enough to drive the logic lines on the L298 chip. You might need a level shifter (a transitor should work) on the logic lines.
Sorry I can't help much with the L298.
I think your 4.4V battery pack should be okay to power the QS board (yes, use Vin next to Vss). Do you use the labels I included?
The 298 chip is now working fine......
pls suggest me how to connect it to QS board as uC (propeller work on 3.3V0
somebody suggest me that 298 will work fine on 3.3V..
and while connecting sensors LDR( from 339 op -amp) to QS board should be there any pull ups resistance
I haven't made a line following robot with the Propeller.
The book Robotics with the Boe-Bot v2.2 has a section about using LDRs with a Basic Stamp. Chapter 6 has the LDR information. It starts on page 193 (page 207 of the pdf).
SO, working with LDR for line follower is creating a problem while testing:-
1.) the response time was very less..
2.) I can't check properly which ldr is working due to light interface..!!
as i am using 100K variable resistance at 26-27Kohms ...........
Pls tell should i continue with LDR or just have IR led?? and if IR then which IR receiver diode one or TSOP 1738 one ( wires)
It is really impressive that you are trying to do this but some of your questions are easy to answer with a little help from a search engine. Why not do some research on your own first rather than asking questions on every aspect of the project? As you modify your code and design you should also post that so others can see how you are progressing.
I was testing my circuit using multimeter......it is working fine with it.
But testing with uC( quick start board) the output is not working well.....I have have tested my code with DIP switch in place of sensor output all code are right i don't know what problem in it........
The component labeled "339 I.C.", I assume that is a LM339 comparator?
Yes, it is LM339..
If you are having trouble with the code I could probably help with it.
Please tell how to add counter with if or case statement i don't have enough time to find in manual.....
( as i want to make a counter which will count at certain condition of sensors as in maze robot)
I'm not really sure what you mean.
Here's an example based on my best guess of what you want to do.
CON
_clkmode = xtal1+pll16x
_xinfreq = 5_000_000
_FirstPin = 16
_LastPin = 20
_AllWhite = %1111
_AllBlack = %0000
_LinesToPass = 5
VAR
long countAllBlack, countAllWhite, countOther
long previousState, pins
PUB Loop | localCharacter
previousState := _AllWhite ' you need to decide what the best starting value is
repeat
pins := ina[_FirstPin.._LastPin]
case pins
_AllBlack:
if previousState <> _AllBlack
countAllBlack++
_AllWhite:
if previousState <> _AllWhite
countAllWhite++
other:
countOther++
previousState := pins
if countAllBlack > _LinesToPass
AllLinesPassed
PUB AllLinesPassed
'Do something after all lines have been passed.
I'm guessing you want to count states of the sensors, but probably only when they change.
CON
_FirstPin = 16
_LastPin = 20
_AllWhite = 11
_AllBlack = 00
_LinesToPass = 5
VAR
repeat
case pins
_AllBlack:
countAllBlack++
_AllWhite:
countAllWhite++
other:
countOther++
AllLinesPassed
PUB AllLinesPassed
Duane
Duane, your a saint for hanging in there, but if found this to be a little offensive from the poster:
Our friend NEEDS to spend some time in the manuals instead of demanding information that is available through a Google search as Franklin has pointed out.
OK, I am driving motor from propeller chip by using 298 as H bridges motor...
all are working fine problem is the motor is not revolving in both direction i have change the port out put from =%01 to =%10 but i work in same direction i am not using any pull up resistance at input pins of 298..!!
here is mode code:-
CON
Delay = 3_000_000
PUB Toggle
dira[0..1]:=%01 'Set I/O pin to output direction
repeat 'Repeat following endlessly
!outa[0..1] ' Toggle I/O Pin
waitcnt(Delay + cnt) ' Wait for Delay cycles
Hi,
I have seen that video and other .....
HI again,
So what should i describe more pls tell......
I have measured the size The motor and tires are feet in the box...( or robot)
I already have schematic of QS board..!!
I haven't every used L298 chips.
I typed this into Google: L298 propeller site:forums.parallax.com/
Hopefully you can find your answers there.
I've only used SN754410 chips to drive motors.
Duane
Hi again Sir,
I use both label and schematic of QS board...!!
Duane
Hopefully someone with more experience using LDRs will answer your questions.
Here are a couple of items I think would be useful in making a line following robot.
Parallax's IR Line Follower Kit (kind of expensive at $39.99, but it has 8 sensors).
Here's another Parallax Kit ($29.99 but only 4 sensors instead of 8).
I've used these sensors from SparkFun to read black and white stripes on a motor encoder. (I think the $2.95 price is pretty good.)
You can also purchase the bare QRE1113 sensor for $1.95.
All the sensors I just listed include an IR LED. I think these are the type of sensors usually used with line following robots.
Duane
and which transistor will be best for 5 IR LED..!!
How can we help without the code you are trying to run?
I'd like to help but I've never used the parts you are using.
The componted labeled "339 I.C.", I assume that is a LM339 comparitor?
Can you give more information about what voltages you measure with your meter and how the IC is connected to the Propeller?
I doubt I will be able to help, but maybe someone with experience with comparitors could help if you provided some more details.
Duane
Yes, it is LM339..
CON _clkmode = xtal1+pll16x _xinfreq = 5_000_000 _FirstPin = 16 _LastPin = 20 _AllWhite = %1111 _AllBlack = %0000 _LinesToPass = 5 VAR long countAllBlack, countAllWhite, countOther long previousState, pins PUB Loop | localCharacter previousState := _AllWhite ' you need to decide what the best starting value is repeat pins := ina[_FirstPin.._LastPin] case pins _AllBlack: if previousState <> _AllBlack countAllBlack++ _AllWhite: if previousState <> _AllWhite countAllWhite++ other: countOther++ previousState := pins if countAllBlack > _LinesToPass AllLinesPassed PUB AllLinesPassed 'Do something after all lines have been passed.I'm guessing you want to count states of the sensors, but probably only when they change.
Duane
It's almost Monday.
here is mode code:-
pls reply fast any one watching this thread.
