Writing data to EEPROM
-=UPDATE=-
Solved! See last posts for example code.
Works with the 24LC256 that comes with the PEKit
Hello,
I am having a little trouble figuring out how to write data to eeprom for the first time.
I have the 32k included with the PEKit, I only need to write maybe four variables of byte length.
I would like to keep these values so the program will 'remember' settings after being turned off.
Not sure how I write the data, or how to make sure there is enough room.
All help is appreciated
J
Hello,
J
PRI writeIt( value ) | startTime if i2c.WritePage(i2c#BootPin, i2c#EEPROM, @X, @value, 1) abort ' an error occured during the write startTime := cnt ' prepare to check for a timeout repeat while i2c.WriteWait(i2c#BootPin, i2c#EEPROM, @X) if cnt - startTime > clkfreq / 10 abort ' waited more than a 1/10 second for the write to finishhttp://www.parallax.com/Store/Components/AllIntegratedCircuits/tabid/154/CategoryID/18/List/0/SortField/0/Level/a/ProductID/400/Default.aspx
Here is the object I think you are referring to:
http://obex.parallax.com/objects/251/
That object is compatible with (just about) any EEPROM that works with the Propeller.
http://forums.parallax.com/showthrea...ogging-and-I2C
I had to spend some time thinking about how to use it but Mike's Basic_I2C_driver works great and is nice and small. I put together a short program to demo reading and writing to eeprom using his driver. I selected an address beyond 32K so be sure to change the start address so the data will fit.
''This my first attempt at writing a program to use ''the Basic_I2C_Driver to read and write to an eeprom ''above the 32KB boundary Since it's only a test I made ''no attempt to prompt for the data to write. ''The constant EEPROMaddress is the start address ''The constant Writechar is the data to be written to the eeprom CON _clkmode = xtal1 + pll16x 'Standard clock mode * crystal frequency = 80 MHz _xinfreq = 5_000_000 EEPROM = %1010_0000 EEPROMaddress = $9000 I2cSCL = 28 Writechar = $ff VAR long eaddr, eeval OBJ ee : "Basic_I2C_Driver" pst : "Parallax Serial Terminal" PUB main ' Initialize serial terminal and i2c driver pst.Start(115200) ee.Initialize(I2cSCL) ' Delay for five seconds repeat 10 pst.char(".") waitcnt(clkfreq/2+cnt) pst.NewLine ' Read 16 bytes of data and output to serial terminal readee pst.Newline ' Write 16 bytes of data don't bother outputing to serial terminal writeee ' Read data just written. Hopefully it will have the proper data readee ' Announce completion :-) pst.str(string("quiting now")) PUB readee eaddr := EEPROMaddress pst.str(string("Reading eeprom")) pst.NewLine repeat 16 pst.str(string("Reading address: 0x")) pst.Hex(eaddr, 4) eeval := ee.ReadByte(I2cSCL, EEPROM, eaddr) pst.str(string(" - ")) pst.Hex(eeval, 2) pst.NewLine eaddr++ PUB writeee eaddr := EEPROMaddress pst.str(string("Writing to eeprom")) pst.NewLine pst.NewLine repeat 16 ee.WriteByte(I2cSCL, EEPROM, eaddr, Writechar) eaddr++ [Finding the space to put it is up to you but you could use the propeller spin tool to find unused eeprom space. Keep in mind that if you use eeprom space in the lower 32K space the data will be overwritten every time you use the propeller tool to program the eeprom.Ok I just spent a few hours trying to get one to work...
First I tried:
http://forums.parallax.com/showthread.php?97625-PE-Kit-Lab-Applications-%96-EEPROM-Datalogging-and-I2C
This seemed like a simple to use object, but everytime I try to use VarBackup, the whole program locks up.
I tried the most simple approach I could think of...
program starts, VAR long value[31], initialize 'value' to 0.
Use pushbutton to increase value.
eeprom.varbackup(@value, @value[31] + 3)
program locks
Next I took a look at:
Memory Storage Management Lightweight
But I couldnt even figure out what commands to use for backing up and restoring, that and the memory addresses were so confusing that I gave up.
Tomorrow I will take a look at:
http://obex.parallax.com/objects/672/
If I cannot get anything going from that either, I will post some code and hopefully someone will have the time to walk me through
I appreciate the help!
This will work with the boot EEPROM and does not require a pull-up
resistor on the SCL line (but does on the SDA line ... about 4.7K to
+3.3V)
Does this mean I need to add a resistor?
Sorry, I have absolutely no previous knowledge in this area at all.... Very confusing to me.
Mike,
I disagree. I think the norm is for Propeller boards to use pull-ups on both the data and clock lines. I recently looked through some of my Propeller boards to note which boards use a pull-up on the clock and which don't.
I found three boards without pull-ups on both lines.
The Propeller Professional Development board
Propeller Demo Board
Jazzed's TetraProp board (He says leaving off the clock pull-up was an oversight.)
These are the boards with pull-ups on both lines.
Propeller Protoboards
QuickStart boards
GG Propeller Platform
Spinneret
Laser Range Finder
Propeller Backpack
Hydra
Tubular's UN3RB3LLY
Kye's real time clock object assumes there are pull-ups on both lines.
Duane
So to use any of these objects, do I need to add a special resistor?
How do I identify which resistor I need to purchase and how exactly should I connect it? (i typically purchase through digikey)
I need this in lamens terms with walkthrough... I did not get any useable info from posts 10-13
Something simple like... to write to eeprom for the first time, you will first need to purchase one of these and place it here orientated like this.
Then download this object. Here is a simple example of how to use this object. here are the commands for this object and how to use them.
I need a very clear and formal learning method. I am getting nothing but bits and pieces with lots of assumed stuff.
I havent really learned a single thing yet about how to do this properly, and do not feel any closer... I'm amazed this hasnt been addressed yet
The sticky thread at the top of the Propeller Forum titled "Propeller Education Kit, Labs, Tools and Applications" list additional labs, tools and applications to use with the PEK. One lab is "EEPROM Datalogging". Here's the thread.
A 10K resistor has the color bands brown, black, orange and either gold or silver.
Most of the schematics of the boards listed in post #12 (one without useful information) are available to download. They will show how the resistors are connected (the Hydra schematic is a bit different than the rest).
I need to backup several long variables, they are to be restored after power is turned back on.
I have tried using Here's the thread. but it does not mention anything about needing an extra pull-up resistor.
As there is no mention to changing hardware, and says it is designed to work with the 24LC256 that comes with the PEKit, I tried using the program as is.
I only used the 'propeller eeprom.spin' object as I do not need hyperterminal.
I used the code as illustrated, but my program immediately locks up when it reaches the eeprom.varbackup call.
I will post my code below in a bit
I basically cut and revised to make it as basic as possible.
General program structure:
One cog monitors buttons, other works with LED.
pushing button increases speed of blinking led.
One problem that I am trying to address by creating a 'databackup' indicator... is when the program is run for the first time, there will be nothing to restore.
So I put an IF statement in to create default variables if the databackup value is < 1
Everytime either the speed or counter variable is changed, it needs to set the databackup variable to 1 and backup both.
On next reboot, the system should start by recovering the 'databackup' variable first, then recover both the speed & counter variable
{{ mem backup test }} CON Button1 = 21 Button2 = 20 LED = 26 OBJ eeprom : "Propeller Eeprom" VAR long stack[50] byte cog[5] long counter[31] long speed[31] long databackup[31] PUB Main eeprom.VarRestore(@databackup, @databackup[31] + 3) ' restore databackup indicator if databackup < 1 speed := 100 ' set defaults if databackup < 1 counter := 5 else eeprom.VarRestore(@counter, @counter[31] + 3) ' restore variables if databackup = 1 eeprom.VarRestore(@speed, @speed[31] + 3) launch2cogs repeat PUB Launch2cogs coginit(3, Buttons(@counter, @databackup), @stack[10]) coginit(4, Blink(@speed, @counter, @databackup), @stack[20]) PUB Buttons(CounterAddress, dbackup) | tmp dira[button1]~ dira[button2]~ tmp := long[CounterAddress] ' temp counter variable repeat if button1 == 1 and button2 == 1 ' hold both buttons for system reset with default variables long[dbackup] := 0 ' turn off backup indicator eeprom.VarBackup(@dbackup, @dbackup[31] + 3) ' backup the indicator value REBOOT ' restart prop if button1 == 1 and button2 == 0 tmp := ++tmp // 4 ' if button pressed, increment temp counter long[counteraddress] := tmp ' write new counter value long[dbackup] := 1 ' write databackup indicator eeprom.VarBackup(@counteraddress, @counteraddress[31] + 3) ' backup new counter variable eeprom.VarBackup(@dbackup, @dbackup[31] + 3) ' backup the indicator waitcnt(clkfreq + cnt) ' wait 1 sec PUB Blink(SpeedAddress, counteraddress, dbackup) | tmp1, tmp2 dira[LED]~~ outa[LED]~~ tmp1 := 0 ' temp counter variable tmp2 := 0 ' temp speed variable repeat if long[counteraddress] <> tmp1 ' if counter variable has changed since last loop tmp1 := long[counteraddress] ' tmp1 grabs new counter value repeat tmp1 ' loop 'counter' many times case tmp1 ' set speed variable based on counter value 0 : tmp2 := 100 1 : tmp2 := 200 2 : tmp2 := 300 3 : tmp2 := 400 4 : tmp2 := 500 !outa[LED] ' flop the LED outa condition waitcnt(clkfreq / tmp2 + cnt) ' wait 1 sec / speed !outa[LED] ' flop the LED outa condition long[speedaddress] := tmp2 ' write new speed value eeprom.VarBackup(@speedaddress, @speedaddress[31] + 3) ' backup new speed variable eeprom.VarBackup(@dbackup, @dbackup[31] + 3) ' create backup indicator waitcnt(clkfreq + cnt)The program will not run, it locks up immediately
PUB NewDistance hypothetical method
keypad := 0 clear the keypad so I can use it for other operations
IF (some conditional statement)
Distance := 0 reset the value so I can change it
Distance := New value input from keypad PRI method
(display the new value on my lcd)
BS2.Write_CodeMem(@Distance,Distance,2) Martin Hebel's object writes to the eeprom
New value := 0 clear the variable so I can use it for other operations
I hope this helps.
Any time two different cogs can access a shared resource, like specific I/O pins or the same hub variables, at the same time, you have to use a lock or semaphore. In Spin, these are provided with the LOCKxxx statements. Somewhere in your program's initialization, you have to get a lock id with:
lockId := LOCKNEW ' lockId is a global long variable
Before each call to eeprom.VarBackup, you need to have a
REPEAT UNTIL NOT LOCKSET(lockId)
After each call to eeprom.VarBackup, you need to have a
LOCKCLR(lockId)
I added some debugging to the LED so I can generally tell where it is locking up by having the LED flash at the beginning of the cogs being launched.
It does blink the LED indicating the cogs have been launched.
In the program, the Buttons routine backs up 2 variables after a button is pressed. In the Blink routine it is supposed to blink the LED depending on the button being pressed... it never gets this far.
So it must be locking up while trying to write the variables in the Buttons routine.
Here is my attempt at your instructions:
Can you correct my code? I normally dont ask for others to write my code as it skips the learning step... but I would LOVE to see a working example.
I am just getting so frustrated with this
{{ mem backup test }} CON Button1 = 21 Button2 = 20 LED = 26 OBJ eeprom : "Eeprom" VAR long stack[50] byte cog[5] long counter[31] long speed[31] long databackup[31] long lockid PUB Main dira[26]~~ outa[26] := 1 waitcnt(clkfreq + cnt) lockId := LOCKNEW eeprom.VarRestore(@databackup, @databackup[31] + 3) ' restore databackup indicator if databackup < 1 speed := 100 ' set defaults if databackup < 1 counter := 5 else eeprom.VarRestore(@counter, @counter[31] + 3) ' restore variables if databackup = 1 eeprom.VarRestore(@speed, @speed[31] + 3) outa[26] := 0 waitcnt(clkfreq + cnt) launch2cogs repeat PUB Launch2cogs coginit(3, Buttons(@counter, @databackup), @stack[10]) coginit(4, Blink(@speed, @counter, @databackup), @stack[20]) PUB Buttons(CounterAddress, dbackup) | tmp dira[button1]~ dira[button2]~ tmp := long[CounterAddress] ' temp counter variable repeat if ina[button1] == 1 and ina[button2] == 1 ' hold both buttons for system reset with default variables long[dbackup] := 0 ' turn off backup indicator REPEAT UNTIL NOT LOCKSET(lockId) eeprom.VarBackup(@dbackup, @dbackup[31] + 3) ' backup the indicator value LOCKCLR(lockId) REBOOT ' restart prop if ina[button1] == 1 and ina[button2] == 0 tmp := ++tmp // 4 ' if button pressed, increment temp counter long[counteraddress] := tmp ' write new counter value long[dbackup] := 1 ' write databackup indicator REPEAT UNTIL NOT LOCKSET(lockId) eeprom.VarBackup(@counteraddress, @counteraddress[31] + 3) ' backup new counter variable LOCKCLR(lockId) REPEAT UNTIL NOT LOCKSET(lockId) eeprom.VarBackup(@dbackup, @dbackup[31] + 3) ' backup the indicator LOCKCLR(lockId) waitcnt(clkfreq + cnt) ' wait 1 sec PUB Blink(SpeedAddress, counteraddress, dbackup) | tmp1, tmp2 dira[LED]~~ outa[LED]~~ waitcnt(clkfreq /2 + cnt) outa[LED]~ waitcnt(clkfreq /2 + cnt) tmp1 := 0 ' temp counter variable tmp2 := 0 ' temp speed variable repeat if long[counteraddress] <> tmp1 ' if counter variable has changed since last loop tmp1 := long[counteraddress] ' tmp1 grabs new counter value repeat tmp1 ' loop 'counter' many times case tmp1 ' set speed variable based on counter value 0 : tmp2 := 100 1 : tmp2 := 200 2 : tmp2 := 300 3 : tmp2 := 400 4 : tmp2 := 500 !outa[LED] ' flop the LED outa condition waitcnt(clkfreq / tmp2 + cnt) ' wait 1 sec / speed !outa[LED] ' flop the LED outa condition long[speedaddress] := tmp2 ' write new speed value REPEAT UNTIL NOT LOCKSET(lockId) eeprom.VarBackup(@speedaddress, @speedaddress[31] + 3) ' backup new speed variable LOCKCLR(lockId) REPEAT UNTIL NOT LOCKSET(lockId) eeprom.VarBackup(@dbackup, @dbackup[31] + 3) ' create backup indicator LOCKCLR(lockId) waitcnt(clkfreq + cnt)re: lock usage, don't indent your to-be-protected code under the lockset line. This (indentation) simply means it's called until the lock is required which is what you want to avoid. Have a look at the manual (v1.2, p.126) LOCKSET + examples.
repeat while lockset(ID) write(parameter) ' don't indent this code lockclr(ID)One of the debugging techniques that I use is to add code that displays values or strings to the PST. A debug statement that will display the values in "speed" and "counter" at any given point is more conclusive than an led.
Kuro:
Ok I will increase the stack. What should I do about the arrays?
One thing I dont understand about the 'propeller eeprom.spin' object is the start address and end address.
I used value[31] as demonstrated in their documentation, I was assuming that was to get an end value, i.e. - VarBackup(@value, @value[31])
In other words, if there is only one variable without an array, the beginning address would be the same as the end address... therefore nothing.
Am I assuming this wrong? Can I simply use a VarBackup(@value, @value) so properly backup the value?
They define the array with 32 longs (you only used 31). Meaning the last element of this (32 long) array is value[31] (first being value[0]). Getting its address will effectively return the address of its first byte which is where the +3 comes in. So if you want to save a single long you'd call
eeprom.VarBackup(@value, @value+3)Did you adjust your lock code?
Just noticed something else. You should get your address/value contexts sorted out. E.g. you pass the address of the speed (array) to your blink method but in there you use the address of the parameter (@speedaddress). In this case you just want speedaddress. It would also be a good idea to keep the reboot command inside the lock.
FWIW, I came up with a minimal test case but it locks up for some reason.
I decided to make it even more simple for the sake of learning:
{{ mem backup test }} CON Button1 = 21 Button2 = 20 LED = 26 OBJ eeprom : "Eeprom" VAR long stack[300] byte cog[5] long counter long speed PUB Main counter := 0 speed := 0 launch2cogs repeat PUB Launch2cogs coginit(3, Buttons(@counter, @speed), @stack[50]) coginit(4, Blink(@counter, @speed), @stack[100]) PUB Buttons(count, spd) | tmp1, tmp2 dira[button1]~ dira[button2]~ tmp1 := 4 ' temp counter variable tmp2 := 4 repeat if ina[button1] == 1 tmp1 := ++tmp1 //5 long[count] := tmp1 if ina[button2] == 1 tmp2 := ++tmp2 //5 long[spd] := tmp2 waitcnt(clkfreq /5 + cnt) PUB Blink(count, spd) | tmp1, tmp2, tmp3 dira[LED]~~ outa[LED]~~ tmp1 := 0 ' temp counter variable tmp2 := 0 ' temp speed variable tmp3 := 0 repeat tmp1 := long[count] tmp2 := long[spd] tmp3 := tmp2 * 2 + 2 repeat (tmp1 + 1 * 2) !outa[LED] waitcnt(clkfreq / tmp3 + cnt) !outa[LED] waitcnt(clkfreq / tmp3 + cnt) waitcnt(clkfreq + cnt)Ill edit this in a bit to try to get a backup to work.
do I need to include the locks?
Do I need to have a 31 array variable for varbackup to find the end address?
If you only want to backup single long variables then you don't need an array. Just use @value and @value + 3 or - assuming a function takes its address - value_addr and value_addr + 3. Array backup works like before - assuming value[N] - @value[0] and @value[N-1] + 3.
re: the array thing, a single long is equivalent to using long value[1] which means you'd end up with @value[0] for the start address and @value[1-1] + 3 for the end address. Both address (@) expressions are @value[0] which is the same as @value.
Update: Also note that data transfer between RAM and EEPROM is byte oriented. So you should be careful re: reading/updating variables while they are being restored/backed up. For example bytes 0 and 1 of a given long are written to EEPROM then another cog updates said long (atomic op) and then we finish with bytes 2 and 3 (of the new value). Which isn't necessarily what you want.
This code works, remembers settings even after powerdown
{{ mem backup test 2 buttons, 1 led button 1 increases blink speed button 2 increases blink amount }} CON Button1 = 21 Button2 = 20 LED = 26 OBJ eeprom : "Eeprom" VAR long stack[300] byte cog[2] long counter long speed long databackup long indicator long blank[0] PUB Main eeprom.VarRestore(@counter, @blank - 1) waitcnt(clkfreq / 2 + cnt) if indicator < 1 counter := 0 speed := 0 indicator := 0 databackup := 0 launch2cogs repeat if databackup := 1 databackup := 0 indicator := 1 eeprom.VarBackup(@counter, @blank - 1) ' restore variables if databackup = 1 waitcnt(clkfreq / 5 + cnt) PUB Launch2cogs coginit(3, Buttons(@counter, @speed, @databackup), @stack[50]) coginit(4, Blink(@counter, @speed), @stack[100]) PUB Buttons(count, spd, dbackup) | tmp1, tmp2 dira[button1]~ dira[button2]~ tmp1 := long[count] tmp2 := long[spd] repeat if ina[button1] == 1 tmp1 := ++tmp1 //5 long[count] := tmp1 long[dbackup] := 1 if ina[button2] == 1 tmp2 := ++tmp2 //5 long[spd] := tmp2 long[dbackup] := 1 waitcnt(clkfreq /4 + cnt) PUB Blink(count, spd) | tmp1, tmp2, tmp3 dira[LED]~~ outa[LED]~~ tmp1 := 0 ' temp counter variable tmp2 := 0 ' temp speed variable tmp3 := 0 repeat tmp1 := long[count] tmp2 := long[spd] tmp3 := tmp2 * 2 + 2 repeat (tmp1 + 1 * 2) !outa[LED] waitcnt(clkfreq / tmp3 + cnt) !outa[LED] waitcnt(clkfreq / tmp3 + cnt) waitcnt(clkfreq + cnt)For anyone else trying to use the eeprom for the first time... im using this object from Andy Lindsay, only the 'propeller eeprom.spin'.
Thread - EEPROM Datalogging and I2C
Object - EEPROM Datalogging and I2C
This code can be used in a public sticky or added to the propeller eeprom docs.spin for first timers like myself.
If this code came as an example with the object, I woulda been sooo happy!
The program still works
How much of a delay should I have after a VarBackup or VarRestore command before using again?
Thank you so much for helping me
