Proteus VSM for the propeller
Jooy
As a user of Proteus, I want to simulate my design on Proteus, but I can not find the VSM for the propeller. Has anyone alread have it? Where could I get the VSM?
System integration (ISIS,VMS,ARES) works very well. As far as the propeller goes, I think that developing a model for those would be quite
difficult. But you should ask Ettore from Labcenter concerning that.
Just my 2c, Friedrich
Thanks!
Jooy
I prefer the tried and true method. Make yourself a decent Dev station with all the bells and whistles that you would need in 90% of your work, and test on the actual hardware. ATM, I am using a platform I designed and built that has a 64k EEPROM, SD card slot, DS1307 (with battery), Video resistor network, 2x20 Newhaven LCD (recent addition to be added later.. for now it flops loose), 4 way D-Pad with center button (needs to be integrated with the jumpers... someday), plus all of the voltage regulators and what nots, and jumper selectable Bananna Jack/Battery supply inputs good from about 6 volts to around 12 volts.. I tied all of those goodies to specific pins through a series of jumpers. This lets me select if I want to use the devices, or the pins by themselves. Finally, each I/O (or related jumper) terminates to a 2x16 Header that I put solder beads on so at any time I can run the I/O's to my breadboards.
And, for the firmware side of it, I made a read-only file I use as a template that has all of the pins labled, needed objects pre-defined, Init routines alredy done. All I have to do from there is do a "Save As", remove what I am not going to need for the current project, and start hammering out the code. Once my design is verified on my proven Dev station, I can go about designing the final hardware. I made that my first serious project with the propeller, and it serves me quite well. Plus, in the building of it, I learned a lot about the language and each individual part involved.
OH! One more thing! I used all socketed parts, just in case I happen to let the "magic smoke" out, and that happens to even the best of us once in a while.
PROP TEMPLATE - Archive [Date 2011.11.01 Time 12.16].zip
