BeagleBone is the low-cost, high-expansion hardware-hacker focused BeagleBoard
Bob Lawrence (VE1RLL)
The BeagleBone is the low-cost, high-expansion hardware-hacker focused BeagleBoard. It is a bare-bones BeagleBoard that acts as a USB or Ethernet connected expansion companion for your current BeagleBoard and BeagleBoard-xM or works stand-alone. The BeagleBone is small even by BeagleBoard standards and with the high-performance ARM capabilities you expect from a BeagleBoard, the BeagleBone brings full-featured Linux to places it has never gone before.
http://beagleboard.org/bone
suggested retail price is $89.
Industry standard 3.3V I/Os on the expansion headers with easy-to-use 0.1" spacing
Because it doesn't have a display interface of its own, it needs an external control terminal either over USB or over the network.
What could you do with this hooked to a Propeller Chip?
The PandaBoard seems to be made by the same organization as the BeagleBoard (the documents have the same street address).
Still, a BeagleBoard can use a USB wifi to provide that aspect - definitely adding a boost of utility to a Propeller that is doing other things.
I'm using IGEP boards from ISEE (Google it) in some projects. They come with WIFI, Bluetooth, USB, real serial, all on board.
Price is comparable and they have a temp spec down to -40C which is required for my projects.
Prop wise, I'd use the Props as I/O slaves and make the Sitara/Boneboard the master.
-Tor
http://buildsmartrobots.ning.com/profiles/blogs/ti-s-latest-robot-controller-beaglebone-makes-it-easy-to-build-sm
