HB25 & Position Encoder question
DiverBob
I was running a simple program to just run a gear head motor for 100 steps and it works just fine most of the time. It ramps up and then ramps back down as expected. The problem is that sometimes when the motor ramps down it then oscillates back and forth rapidly. Has anyone else run into this type of problem? It happens enough that it makes the movement unreliable and I haven't been able to come up with a solution so far.
Bob
Bob
I'm going to try adjusting the positioning of the encoder closer to the encoder wheel and see if that makes a difference.
Bob
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/position/List/0/SortField/4/ProductID/665/Default.aspx
It should show what all the initial hard coded values are.
Robert
I'm taking a break and will give it another shot later, maybe I'll see something I haven't thought of before.
Robert
I have experienced same and it is really frustrating... I have two Morot Mount and Wheel with position controller. One wheel works fine (sending serial signal from arduino) but the other one just run full speed for a few seconds and then start jerk back and forth...
Please share a solution if you have found a one?
