Hot chip
Tumbler
Heys
Trying to use a 74595 at 3.3V. (with a PPDB)
When i wire pin 10 to +3.3V the chip gets really hot.
First i was thinking for a shortcut, but building it 4 times from scratch.
Just blowed my 4 th chip.
What's wrong here?
My MM74HC595 seems identical with a 74595
What's wrong here?
If not go with 74AHCT595.
I connect pin 10 direclty to Vdd (3.3v) and it works.
How high are your OHM values on your resistors?
It's rated max 35 mA per pin.
Biulded it 4 times
Like i said, im using the propeller development board. I'm sure those resistors are ok.
Used a 10k resistor (pullup) to 3.3V
MY 5th chip is getting hot here.
No output anymore.
Now i have 5 DIP mini electric cookplates. Maybe Barbie can use them.
You are placing the dip chip along the center channel of the protoboard?, just checking to make sure.
I would suggest checking the voltage/signals on all the pins using pin 8 as the reference (ground), preferably with a scope so you can see the signals, or with a meter if a scope is not available. All the voltages should be positive with respect to pin 8.
I hope this helps...
Jim...
Seems they are working perfect.
Removing and replaced by a MM74HC595N results in hot chip.
hallelujah
