Probability Puzzle
Phil Pilgrim (PhiPi)
Found this one on Reddit:
(I hereby disclaim responsibility for whatever migraines this might cause. And, no, I have not figured out the answer yet myself.)
If you choose an answer to this question at random, what is the chance you will be correct?
A) 25%
50%
C) 60%
D) 25%
C) 60%
D) 25%
But I've got two choices that are the same, and both are chances of hitting 25%, which would mean I've got a 50% of getting the right answer.
But the chance of hitting the right answer of 50% is only 1 out of 4, so..... so..... uh... uh...
Was this sponsored by the people who make Advil?
EDIT: what would happen if you made choice C equal to 0% ?
Dave
Average Probability = (50% + 25% + 25%) / 4 = 25%
How the heck can you read Reddit and still be so productive??!
Must go refresh Reddit now.
But couldn't one of the choices be 0% and you would still be wrong?
If choice C were 0%, then you'd have a 25% chance of selecting C. Right?
And since two of the choices are 25%, that gives you double the chance of getting it right. Right?
And since double 25% is 50%, then....
Maybe there's no right answer, which might be saying something different than saying 0%. But then what does it mean?
http://www.youtube.com/watch?v=OQSNhk5ICTI
Oh man, little warning next time?
The way the puzzle is stated in the original post the answer would be zero.
EDIT: Changed "6 possible ways" to "5 possible ways".
As I see it, right so far. It says "what is the chance". So the answer to that does not need to be one of the answers given...
Next path you can take is... Are any of the answers correct?
Or another path you can take is that you could randomly choose 25%. Since that answer is given twice, you have a greater chance of choosing that answer! So the question is...
Is 25% the correct answer? If yes, then you would have a higher percentage chance of choosing the correct answer.
If 25% is not correct, then you would have a lower percentage chance of choosing the correct answer.
So that 33 1/3 chance should be adjusted up/down to reflect that.
I guess you could assume that 25% was the correct answer, then figure that in and see what you get.
And then assume that 25% was the wrong answer, then figure that in and see what you get.
There is a 50% chance of choosing 25% so either A or D has a 0% chance of being correct.
There is a 25% chance of choosing 50% so choosing B would also have a 0% chance of being correct.
There is a 25% chance of choosing 60% so choosing C would also have a 0% chance of being correct.
Result: if you choose an answer at random then there is a 0% chance you'll be correct.
disclaimer: this is a total guess.
So what if you changed the problem to the following...
(Sorry for doing this, but I could not resist!
C) 60%
D) 0%
A) 0%
C) The question is meaningless.
D) 25%
