CODE block font
David Betz
Did the font used for CODE blocks change recently? The font is way too big. You can't see enough code at once. Is there any way to change back to the previous font or a smaller version of the new font?
Is there any chance you could switch the forums back to the font we were using before while you work to resolve this problem?
David
Still checking other things to make all these features 'sing'... do features have vocal chords? I'm not sure anymore.
Is there any way to add a new tag to the forum software? Could you use [PARALLAX] for code that requires the Parallax font?
Anyway, it appears what I was told may be wrong; I think the Parallax font looks ok small... but difficult to read easily.
============================================= Connection Diagram ============================================= ┌──────┐ │ │ R0 D0 │ Px├───────┐ │ │ │ └──────┘  Propeller MCU (P8X32A) Components: R0 = 100Ω D0 = Blue LED, 3.2V @ 20mA Px = Desired Propeller Pin ============================================= }}another addition for personal reference since I'm making corrections directly rather than on my test-site... bad Bump.
That's a way easy suggestion, I could play with that also.
Did you (of all people) ever really doubt that?
http://www.youtube.com/watch?v=QH2-TGUlwu4
That size is definitely better.
I wrestled with this issue for the Spin autodocumenter. I settled on this for my pre CSS:
font: 10pt parallax,courier,monospaced;
line-height: 97%;
This is what it looks like:
Below 10 points, the font starts to look pretty crappy.
Heh, did quoting code always make it look all jagged? That's easy to fix too.
Yes, that. The font-style for quote_container is italics which makes all the diagrams in the code get all freaky-deaky, but if I force it all normal than any intentional styling could be lost.
BTW, if you can do it, boldface type in a code block should have letter-spacing set to -1px. The reason is that the Parallax typeface does not come with a bold font that preserves character width, but shifts each normal character right and overlays it with itself to make it look fatter, and that increases the character width by one pixel. The -1px adjustment for bold characters undoes this. Here's an example of the problem:
Don't make me look silly vbulletin...
