To all of you who have made a Propeller based PCB - Take this poll
Hi,
Considering how I have been in the Propeller community for a while, I have started to notice an interesting trend in the terms of Propeller based PCBs that the users of this forum have been making. It appears that the vast majority are NOT projects, but rather, modules. I'd be willing to bet there are over 10 different PCBs for the simple Propller-EEPROM-Xtal setup out there. Therefore, to confirm or disapprove of this, I would like willing forum members who have made a PCB to take this poll: Is your PCB for a project of yours, or a platform?
If you have made multiple, please vote for the one you have made the most of.
Microcontrolled
Microcontrolled
My 'Propeller Breadboard' platform is modeled after the 'Bare Bones Board' (Arduino) from ModernDevice. It brings all the Propeller I/O pins out to a single row header on the edge of the board, and has pins that will transfer regulated +5V and GND to the breadboard power rail (it has a 3.3V regulator as well). I can plug this into a breadboard and take up virtually zero real estate on the breadboard for my Propeller and its support circuitry (xtal, EEPROM, etc).
I have a version of experimental "DemoBoards" I named it the "LunchBox" is the one usually played with as it is self contained in a Sony small BetaCam tape case with a 6" long breadboard on its top and could go to work with me in the laptop bag. I also have two surviving "DracBlades" both in keyboards ( for my Z80 habit,(sniff) I can handle it).
I have got a QF Prop but to allow me to do Toner Transfer PCBs, single and double sided, I recycle the 40DIPs, and other components, over and over ...
To date I have probably made 30+ PCBs for various projects
I wanted modules for various things so that I can configure whatever is desired from a number of basic modules. Recently I made a lot of these modules and they are coming together nicely. I use a number of these modules on an almost daily basis.
Also, I'm working on another Propeller project in my spare time. It is a control / user interface board for a 2-axis pen/laser plotter. So far it's going well, In my opinion, the Propeller platform lends itself very well to both embedded applications and to general purpose use. I find the architecture very intuitive and easy to understand. I never had that with either Arduino/Atmel nor PIC platforms.
I created a couple of PCBs for a project, including an ad hoc part or interface (GPS, Xbee, SD, and so on), but I included also pins compatible with gadget gangster's pinout.
So I have a generic PCB, platform like, but born with a project in mind (or to fit a case, or a display dimension). The board has been adapted to be used in other projects, so we are still in this grey area... where shall I place mi tick?
Massimo
