Snow blower tracks
I just finished welding the frame on my tracked robot. And couldnt wait the get the electronics mounted before I drove it.
Also in the video it gets stuck cause of the 2 transmission handles the sick down and reduce the ground clearence , but i fixed that
when i made the hold down strap for the battery.
Also after the first test run I might just lay the batteries flat to get more room and ground clearence.
Snowblower tracks
350 watt wheel chair motors
Snowblower tracks
2x25 Sabertooth motor driver
Spekstrum rc transmitter and reciver.
2 17ah batteries
http://www.youtube.com/watch?v=8IUOcqocCKM&feature=feedu
http://www.youtube.com/watch?v=4Ucs_7opJiI
Snowblower tracks
Snowblower tracks
2 17ah batteries
Where in the world did you scrap two wheel chair motors from???? I want some!!! I don't think I could resist the temptation to build a Johnny 5 with that setup
You have to wait but you can get a whole chair minus the batteries for between 50 -250.
Thank you! That's another perfect situation where searching for the correct keywords makes all the difference. I've been looking on CL for "Motor" "DC motor" "gearmotor" etc, for some time now.
Good luck with your project. It really looks like it'll scoot
Also laying the batteries on the side will increase the width by just 3 inches so I got more metal and will do that tonight. And it will give me a flat surface to mount my electronics.
83 hits on eBay this morning looking for "wheelchair motor". http://bit.ly/qiLaxf
HTH,
Amanda
http://www.searchtempest.com/
craigslist search engine you can get the whole chair minus or dead batteries for that much.
motors, wheels, controller, joystick, charger.
I love the video with the camera mounted on the robot.
Just got for 49 dollars tax includes
And it works and charges
Nice work.. Can you please tell me how you got the wheel chair shaft mounted into the drive wheel. What mods did you have to do?
http://www.ebay.com/itm/4-COUPLER-17MM-KEYED-SHAFT-ADAPTER-HUB-FLANGE-PTO-/400241768181?pt=LH_DefaultDomain_0&hash=item5d3044b6f5
My track drive hubs are 2 piece plastic with a sprocket in between and bolted together.
I machined the side of one of the track hubs made a spacer to replace the sprocket and bolted the drive wheel to the new motor coupler/hub.
I am in the process of redoing the frame again in aluminum so i will take and post a bunch of pictures.
Also i removed the freewheeling lever and geqarbox cover. now the chassis plate is also the gearbox cover.
http://www.youtube.com/watch?v=OQn5SD7UQgw&context=C3197620ADOEgsToPDskIMttUI6fYjYEr32b7AgA1K
Paul
This is a very good project.
I'm impressed.
I've built pedal powered snow plows years ago, but could not develop the 175 watts needed to make them work.
I'm only able to do 100 watts pedal power.
Have you thought about turning your plow attachment into a blower attachment?
It's a great thing that you have built.
I wound up with the same motors and keyed hub. The problem for me is that the hub hole pattern does not match that of the tread wheel. I'll need some sort of adapter / spacer with a dual bolt pattern, or I assume you drilled through the plastic in the tread wheel and used an appropriately sized spacer?
Did you knock the existing bolts out of the hubs? Or did you make use of them?
I have not tried anything like your project, so please forgive my idea... would other types of transmissions work for your project? Like a hydrostatic transmission?
Just a thought. Good Luck!
