First screenshots of the Open Protocol Analyzer
Here some screenshots on what's coming soon:
Use the Channel view to manage which protocol channels (SPI, RS232, I2C...) to analyze and configure settings
Use the Trigger view to configure simple- or arbitrarily complex triggers. Both Channel and Trigger configuration strings can be included in spin code.
Events are graphed on a timeline, available as a list, and you can click events to view more details.
Comes with adapters for standard protocols- but you can write your own to support anything. Uses ViewPort new "file download" feature to cache bursts of high speed events. Reconciles Prop's timestamp with PC's time to support long (days/week?) sessions with microsecond accuracy.
Any thoughts?
Hanno
Any thoughts?
Hanno
Years ago I had some serial<>ethernet converters whose software SerialIP had a similar timestamping feature. It was so useful I'd often connect serial devices via the ethernet (rather than rs232), just to be able to study the stream. Saved heaps of time.
Very Nice
Would it be possible to view the data packets in HEX, BIN, or DEC format?
Yes, you'll be able to configure how to view the data- both in the user interface and programmatically with configuration strings.
Hanno
