Catalina 3.3 - Page 5 — Parallax Forums
Catalina 3.3
1235711
  • RossHRossH Posts: 5,692
    edited 2011-10-16 21:46
    @Dr_Acula... Yeah, that is the exact line of code i put between the brackets where it says //insert code here. I know it is not the board, because i have used it for other video applications already. Do you think it sent the message to the serial terminal?
    Just thought of another possibility - did you by any chance insert the printf line on the same line as the // - in which case it is just a comment?
    Ross.
  • RavenkallenRavenkallen Posts: 1,057
    edited 2011-10-16 21:54
    I switched the mode to release mode like it said to do in the manual... How do i post a build log?
    And no, i left the comment in the same place and put the print command one line below it.
    Oh, nevermind... I copied this from the build log.
    Build: Release in catalinatest
    Compiling: main.c
    1 file(s) moved.
    Catalina Compiler 3.3
    Linking console executable: bin\Release\catalinatest
    Homespun Spin Compiler 0.30
    parsing C:\Program Files\Catalina\target\lmm_default.spin
    parsing C:\Program Files\Catalina\target\Catalina_Common.spin
    parsing C:\Program Files\Catalina\target\Catalina.spin
    parsing C:\Program Files\Catalina\target\Command_Line.spin
    parsing C:\Program Files\Catalina\target\Catalina_CogStore.spin
    parsing C:\Program Files\Catalina\target\Floating_Point.spin
    parsing C:\Program Files\Catalina\target\SD_Card.spin
    parsing C:\Program Files\Catalina\target\Clock.spin
    parsing C:\Program Files\Catalina\target\HMI.spin
    parsing C:\Program Files\Catalina\target\Catalina_HMI_Plugin_HiRes_Tv.spin
    parsing C:\Program Files\Catalina\target\Catalina_CogCount.spin
    parsing C:\Program Files\Catalina\target\Catalina_comboKeyboard.spin
    parsing C:\Program Files\Catalina\target\Catalina_comboMouse.spin
    parsing C:\Program Files\Catalina\target\Catalina_mouse.spin
    parsing C:\Program Files\Catalina\target\Catalina_HiRes_TV_Text.spin
    parsing C:\Program Files\Catalina\target\TV_Half_Height.spin
    parsing C:\Program Files\Catalina\target\Graphics.spin
    parsing C:\Program Files\Catalina\target\Proxy_IO.spin
    parsing C:\Program Files\Catalina\target\Extras.spin
    parsing C:\Program Files\Catalina\target\Catalina_LMM.spin
    compiling lmm_default.spin
    compiling Catalina.spin
    compiling Command_Line.spin
    compiling Catalina_CogStore.spin
    compiling Floating_Point.spin
    compiling SD_Card.spin
    compiling Clock.spin
    compiling HMI.spin
    compiling Catalina_HMI_Plugin_HiRes_Tv.spin
    compiling Catalina_CogCount.spin
    compiling Catalina_comboKeyboard.spin
    compiling Catalina_comboMouse.spin
    compiling Catalina_mouse.spin
    compiling Catalina_HiRes_TV_Text.spin
    compiling TV_Half_Height.spin
    compiling Graphics.spin
    compiling Proxy_IO.spin
    compiling Extras.spin
    compiling Catalina_LMM.spin
    compiling Catalina_Common.spin
    writing 9880 bytes to bin\Release\catalinatest.binary
    code = 80 bytes
    cnst = 0 bytes
    init = 4 bytes
    data = 4 bytes
    file = 9880 bytes
    Process terminated with status 0 (0 minutes, 33 seconds)
    0 errors, 0 warnings
    Build log saved as:
    edited 2011-10-16 22:00
    Can you post your code too?
    There is just one small possibility it is the same as a bug I saw briefly in amongst a frenzy of coding last night, so I need to ask - with that flashing cursor, is it in the top left of the screen, or is it about 1/8th of the way in and 1/8th of the way down the screen?
    edited 2011-10-16 22:06
    Select Settings -> Compiler and Debugger from the main menu. Make sure Catalina C Compiler is the selected compiler, and then select the Other Settings tab in that dialog box. On that tab, make sure the Compiler logging option is set to Full Command Line and the Save Build log to HTML file when build is finished option is selected. There is a picture and some text on page 25 of the Getting Started with CodeBlocks document that may help you.
    Then rebuild your project as usual. Examine the build log when finished (which is saved in a HTML file) - either click on the file to open it and cut and paste the results to a new file, or just post the file that it says is generated.
    Ross.
    edited 2011-10-16 22:20
    @Dr_acula... It is not all the way in the corner, but it is not an 1/8 of the way down horizontally or vertically. The actual picture is somewhat blurry to.
    @Ross... Oh, sorry. I posted the build log in the post above. What am i looking for in there anyway? It said it didn't have any errors or warnings? I am going to bed now(It's like 1: 30 over here), but i will be back in the afternoon tomorrow. Thanks Dr_acula and Ross for the help thus far:)
    edited 2011-10-16 22:25
    I want to see the actual Catalina command executed. Can you set the Compiler logging option is set to Full Command Line (as described in my previous post) and repost the build log? Also, please post the code as well.
    Ross.
    edited 2011-10-17 05:58
    Hi Ross,
    I need some help! I'm having a huge amount of trouble with code::blocks and after 3 hours of coding I still can't get a "hello world" on the screen. I have tried so many combinations and permutations that I'm just not sure where to go next.
    I have it working well from my IDE but I can't replicate this in code::blocks. There are things that don't make sense, like when you change a whole lot of settings in Project/Build Options, and then hit Build/Build, it comes up with "Target is up to date, nothing to be done". This does not make sense when you add or delete a library like stdio. I think Build/Build is for compiling on a PC which doesn't mean anything for our programs, is that right? So instead, use the Tools menu.
    Simple stuff first:
     * main.c - main program
    #include <stdio.h>
    int main(int argc, char *argv[])
        printf("Hello World\n");
        while(1) ; // the propeller reboots on exit - this line prevents that
        return 0;
    Select Target is "release". I have run Build XMM utilities. I have changed SET_MEM to 512k
    I'd like to jump straight to XMM because I know this works.
    In Project Build Options I have checked:
    Dracblade platform
    libc standard c library
    VGA high resolution
    and nothing else.
    I am confused about the Build XMM utilities as it asked some questions about the cache, so I am not sure which is the correct cache setting, what you put in the Build XMM utilities or what you put in that list of checkboxes.
    So that is the first bit that is confusing, where to store information.
    I also ran into many errors last night where in the final command line, Dracblade ended up there twice. So this might be a related problem.
    So, in Tools I run "Download to XMM ram" and I get this message at the bottom of the screen
    Launching tool 'Download to Hub RAM': payload.exe Hello (in C:\Propeller\Hello\bin\Release)
    stderr> Error: Hello is larger than 32768 bytes - this is too large to load as the first file
    Tool execution terminated with status 1
    Launching tool 'Download to XMM RAM': payload.exe XMM Hello (in C:\Propeller\Hello\bin\Release)
    stderr> Using Propeller (version 1) on port COM1 for first download
    stderr> Using Secondary Loader on port COM1 for subsequent download
    Tool execution terminated with status 0
    So there seems to be an error about the file being >32k, which it will be because it is an XMM program. And so it downloads for a while and I get a flashing cursor but no text.
    So how do I get it to compile a file?
    Before, I was sure there was a screen that flashed up with all the compilation. I can't see this at the moment. So before I get to the download stage, how do I compile a file? (This is a step I added at the top of my IDE as it is a quick way to find bugs before downloading. At one stage writing code I was recompiling after adding every new line in C).
    I was expecting recompilation (but no download) to be Build/Build but it keeps saying "nothing to be done"
    Any help here would be most appreciated!
    Addit: I worked out how to force a recompilation - change one line in the code. That is odd behaviour as I figure that if hit compile then it compiles, regardless of whether it already did ten minutes ago. But we can live with that.
    So a recompilation and we have this error message:
    Build started on: 17-10-2011 at 22:31.25
    Build ended on: 17-10-2011 at 22:31.26
    -------------- Build: Release in Hello ---------------
    catalina.exe -DHIRES_VGA -DLARGE -DDRACBLADE -DHIRES_VGA -DDRACBLADE -c main.c -o obj\Release\main.obj
    catalina.exe -o bin\Release\Hello obj\Release\main.obj -DHIRES_VGA -DLARGE -DDRACBLADE -DHIRES_VGA -lc -DDRACBLADE
    Item has already been added. Key in dictionary: 'HIRES_VGA' Key being added: 'HIRES_VGA'
    Output size is 6.80 KB
    Process terminated with status 0 (0 minutes, 0 seconds)
    1 errors, 0 warnings
    Alright, I have a blank VGA screen. That is a start, and I don't care that there is no text on it.
    First, I got it to compile.
    In Project/Build Options, UNCHECK everything except the libc.
    Then change a character in the code to force a recompile.
    And compile, and that gives no errors and then you can do a download. No Hello World as yet, but first I need to understand those settings.
    In Project/Build Options there seems to be a mix of settings. Some are libraries that you have to include and that makes sense. But some, like the platform you are using, are defined elsewhere, and if you check them in this list then they are added twice to the command line. That seems confusing to me - I'd be expecting settings to only be set in one place. So if they are set in Build XMM Utilities, does that imply that if you are not using XMM then you don't run Build XMM Utilities, and hence you DO set those variables in that checkbox list?
    This is my compile log
    Build started on: 17-10-2011 at 22:42.02
    Build ended on: 17-10-2011 at 22:42.05
    catalina.exe -o bin\Release\Hello obj\Release\main.obj -DHIRES_VGA -DLARGE -DDRACBLADE -lc
    parsing C:\Program Files\Catalina\target\xmm_default.spin
    parsing C:\Program Files\Catalina\target\Cache.spin
    parsing C:\Program Files\Catalina\target\Catalina_Float32_A_Plugin.spin
    parsing C:\Program Files\Catalina\target\Catalina_HMI_Plugin_HiRes_Vga.spin
    parsing C:\Program Files\Catalina\target\Catalina_VGA_HiRes_Text.spin
    parsing C:\Program Files\Catalina\target\Catalina_XMM.spin
    parsing C:\Program Files\Catalina\target\Catalina_HUB_XMM_Loader.spin
    compiling xmm_default.spin
    compiling Cache.spin
    compiling Catalina_Float32_A_Plugin.spin
    compiling HMI.spin
    compiling Catalina_HMI_Plugin_HiRes_Vga.spin
    compiling Catalina_VGA_HiRes_Text.spin
    compiling Catalina_XMM.spin
    compiling Catalina_HUB_XMM_Loader.spin
    writing 32768 bytes to C:\Program Files\Catalina\target\xmm_default.eeprom
    renaming output file from bin\Release\Hello.binary to bin\Release\Hello_temp.binary
    combining target and program to bin\Release\Hello.binary
    writing 49088 bytes to bin\Release\Hello.binary
    code = 15720 bytes
    cnst = 232 bytes
    init = 156 bytes
    data = 172 bytes
    file = 49600 bytes
    Output size is 6.81 KB
    Process terminated with status 0 (0 minutes, 2 seconds)
    So why no "Hello World"
    And this is the bit that is maddening, because when I test it on my vb.net IDE, it does not work either. And it worked last night. And the reason it does not work is because I have done a reinstall of the code::blocks package since last night, and it probably has wiped xmm.binary or some other file that I have been fudging for each update of catalina by manually copying into a directory.
    Do I go back to an old version that works (3.0)?
    Do I try to persevere with the code::blocks version, knowing that the error in 3.3 is the same from code::blocks as from my IDE?
    Do I try to copy files from the old working version to the new version, knowing that this will make it very hard for you to debug what is working as there will now be old files in amongst new files?
    I just don't quite know what to do next, and this is now my 6th reinstall of the 3.3 package as I have been down this road many times.
    Sorry to make it so complicated. To find this error I need a working version to troubleshoot against, so I need to be really clear about what steps I take along the way.
    So, this is the code and the command line that work on my version 3.0 code from my IDE, warts and all with several files moved and copied around the place. Can you replicate this command line in code::blocks with version 3.3?
    /* Traditional first C program */
    #include <stdio.h>
    int main ()
           printf("Hello, World!\n");
           while (1);                                                    // Prop reboots on exit from main()!
           return 0;
    catalina -lcx -D PLUGIN -x5 -M 512k -D DRACBLADE -D SHARED_XMM -D HIRES_VGA NEW.C
    and the version 3.0 compilation is
       SETTING UP CATALINA
    CATALINA_DEFINE  = [default]
    CATALINA_INCLUDE = [default]
    CATALINA_LIBRARY = [default]
    CATALINA_TARGET  = [default]
    CATALINA_LCCOPT  = [default]
    CATALINA_TEMPDIR = [default]
    LCCDIR           = C:\Program Files\Catalina
    Catalina Compiler 3.0
    parsing C:\Program Files\Catalina\target\Catalina_HMI_Plugin_HiRes_Vga_No_Mouse.spin
    parsing C:\Program Files\Catalina\target\Catalina_SD_Plugin.spin
    compiling Catalina_HMI_Plugin_HiRes_Vga_No_Mouse.spin
    compiling Catalina_SD_Plugin.spin
    writing 69724 bytes to NEW.binary
    renaming output file from NEW.binary to NEW_temp.binary
    combining target and program to NEW.binary
    code = 35620 bytes
    cnst = 468 bytes
    init = 176 bytes
    data = 652 bytes
    file = 70236 bytes
    Payload XMM NEW
    Using Propeller (version 1) on port COM1 for first upload
    Using port COM1 for subsequent uploads
    Press any key to continue . . .
  • RaymanRayman Posts: 15,880
    edited 2011-10-17 06:47
    Ross, I was up late working on it, so I probably just did something dumb... I'm sure I'll figure it out, next time I get a chance to work on it.
    Anyway, here are the files that I think were giving me trouble:
    http://www.rayslogic.com/Propeller/Products/FlashPoint/Catalina/FlashPoint_CfgDef_Platform.zip
    But, like I said, I wouldn't bother with it yet.
    edited 2011-10-17 09:30
    I'm back!!! Here is the code i was using
    #include <stdio.h>
        // insert your code here
        printf("Hello world\n");
        return 0;
    As for the new build log... I made sure the full command line option was selected. Here is the build log...
    Build started on: 17-10-2011 at 01:37.50
    Build ended on: 17-10-2011 at 01:37.58
    -------------- Build: Release in catalinatest ---------------
    catalina.exe -DASC -DTINY -c main.c -o obj\Release\main.obj
    1 file(s) moved.
    catalina.exe -o bin\Release\catalinatest obj\Release\main.obj -DASC -lc -DTINY
    compiling HMI.spin
    code = 80 bytes
    cnst = 0 bytes
    init = 4 bytes
    data = 4 bytes
    file = 9880 bytes
    Process terminated with status 0 (0 minutes, 8 seconds)
    edited 2011-10-17 15:45
    Ravenkallen: I am no C expert, but this bit looks wrong to me..
        return 0;
    Shouldn't this be???
        while(1) {} // the propeller reboots on exit - this line prevents that
    //    return 0;
    edited 2011-10-17 15:46
    #include <stdio.h>
        return 0;
    code = 80 bytes
    cnst = 0 bytes
    init = 4 bytes
    data = 4 bytes
    file = 9880 bytes
    Ok - I can see and reproduce the problem, but I'm not sure exactly what's causing it in your case. Compiling that program cannot possibly generate only 80 bytes of code, since using printf() pulls in almost the entire stdio library - on my system compiling your program generates 14144 bytes!
    However, compiling the original main.c (or when I remove the printf() statement) does generate exactly 80 bytes.
    Somehow you are editing one file, but compiling a different one. Can you please compile by right-clicking on the catalinatest project node in the navigation pane and selecting rebuild from that menu?
    Also, could you close all your open source files in Code::Blocks, and then re-open main.c by right-clicking on the one under the catalinatest/Sources node? - that way, you will know you are editing the correct main.c
    Ross.
    edited 2011-10-17 15:48
    Cluso99 wrote: »
        return 0;
    //    return 0;
    Hi Cluso,
    That "return" is required to avoid a warning message since main() is defined (by the ANSI C standard) to return an int. It is never executed (and may in fact be optimized away by the compiler - I've never checked).
    Ross.
    edited 2011-10-17 16:04
    Ross, I think I found that issue...
    I tried to fix that other problem where it wouldn't complain if I did "large" on SuperQuad.
    Here's what I substitiuted (I think you gave this to me):
    #ifndef NO_RAM
    #define NO_RAM
    #ifdef LARGE
    ERROR : LARGE MEMORY MODE NOT SUPPORTED BY THE SUPERQUAD
    #endif
    #endif
    It complains about the colon after "ERROR" says expected "(eol)", got ":"
    edited 2011-10-17 16:15
    Dr_Acula wrote: »
    Hi Ross,
    Like "make", the Code::Blocks build engine does not understand anything except source file changes. If you make a configuration change and say "build" it will not build anything - no source files have changed so it thinks the binary is up to date. To force a build, use Build->Rebuild instead.
    Dr_Acula wrote: »
    Simple stuff first:
    #include <stdio.h>
        return 0;
    Dracblade platform
    VGA high resolution
    and nothing else.
    Not even LARGE or SMALL? Please post the actual build log.
    Dr_Acula wrote: »
    It doesn't usually matter what you set, as long as you set the same cache size (or no cache) in both places.
    Dr_Acula wrote: »
    What information?
    Dr_Acula wrote: »
    You have specified options in two places. In the build options dialog, select the main project node as well as the release node and make sure you only use one of the two sets of options.
    Dr_Acula wrote: »
    Th build log is cumulative - you previously executed a "Download to Hub RAM". But the "Download to XMM RAM" looked like it worked ok. You can clear out the old contents of the build log by right clicking on the "Build Log" title bar.
    Dr_Acula wrote: »
    As above, use Build->Rebuild
    Dr_Acula wrote: »
    Dr_A, you are posting way too much for me to respond to in one post. Please try and keep to one post per issue.
    Dr_Acula wrote: »
    As I said before, you don't need to copy XMM.binary anywhere - Payload looks for it in the bin directory, which is where the "build utilities" puts it.
    Let's get these issues sorted out, and then try again to identify if anything else is causing you a problem.
    Ross.
    edited 2011-10-17 16:17
    Rayman wrote: »
    #ifndef NO_RAM
    #define NO_RAM
    #ifdef LARGE
    #endif
    #endif
    That's intentional - Homespun has not have a general #error directive (like C does), so when I discover an error condition I artificially generate an error. This causes homespun to spit out the actual line as part of the error message, and I then detect that in Code::Blocks.
    Ross.
    edited 2011-10-17 16:19
    Ross, but the problem is that I have "small" selected...
    Maybe this is related to that thing you mentioned earlier where xmm tools is always build with "large" specified in CodeBlocks...
    edited 2011-10-17 16:21
    Rayman wrote: »
    #ifndef NO_RAM
    #define NO_RAM
    #ifdef LARGE
    #endif
    #endif
    Also, I think there is an error in that code that I found previously. I modified that code to this:
    #ifndef NO_RAM
    #define NO_RAM
    #endif
    #ifdef LARGE
    #endif
    edited 2011-10-17 16:24
    Ross, you're too fast! :) I was updating my previous post. I think the issue may be that the CodeBlocks "Build XMM Tools" always specifies "LARGE" on the command line.
    Could that be?
    edited 2011-10-17 16:34
    Rayman wrote: »
    Could that be?
    Possibly. Where do you see the "LARGE" - I'll have to check this out when I get home.
    Ross.
    edited 2011-10-17 16:52
    Ross, Ok, I think the problem is in the "build_all.bat" file here:
    :superquad
    @echo on
    call build_tmp_var %1 %2 %3 %4 %5 %6 %7 %8 %9 LARGE
    @echo on
    homespun Payload_XMM_Loader -L "%TMP_LCCDIR%\target" -b -o XMM %TMP_VAR%
    homespun "%TMP_LCCDIR%\target\xmm_default.spin" -L "%TMP_LCCDIR%\target" -b %TMP_VAR% -o Flash_Boot -d
    @echo.
    @echo off
    goto copy
    I'm tempted to change that LARGE to SMALL...
    edited 2011-10-17 16:55
    Rayman wrote: »
    :superquad
    @echo on
    @echo on
    @echo.
    @echo off
    goto copy
    Yes, give it a try. As I said earlier, I specify LARGE only to force the inclusion of XMM functionality. SMALL may do the same. If not, I'll fix it when I get home. In hindsight, I probably should have used SMALL, since all XMM boards will support SMALL, but not all will support LARGE.
    Ross.
    edited 2011-10-17 16:56
    Ross, on a different topic... What are the chances of this obfuscated chess code compiling?
    http://nanochess.110mb.com/chess1.html
    edited 2011-10-17 17:39
    Rayman wrote: »
    Probably pretty good. Actually, I just compiled it :)
    code = 78180 bytes
    Of course, I don't know if it will actually run - it depends on how much run-time stack it might need. Chess programs can be pretty "deep"
    Ross.
    edited 2011-10-17 17:45
    Cool! I'll have to try it out.
    BTW: I think I'll just remove the large error checking in Flashpoint_def.inc for now, because I'm trying to do a guide for the current version...
    edited 2011-10-17 17:57
    Rayman wrote: »
    Here's what I had to do to compile it, since it appears to want three arguments to main:
    1. Save the file as toledo.c and add it to the project.
    2. Replace main with my_main throughout the file toledo.c
    3. Replace the code in main.c with the following:
    void main() {
           my_main(0,0,0); // <- not sure what to put here
    Rayman wrote: »
    Sounds ok.
    edited 2011-10-17 19:09
    Hi Ross,
    Thinking through what works (v3.0) and doesn't (3.3), it probably is the setup process. I've reinstalled v3.3 so many times I suspect I'm leaving something out. I am now thinking that with respect to XMM programs, there are two things that need running, not one. From page 17 of the manual:
    Note that some of Catalina&#8217;s build scripts (e.g. the build_all script in the utilities
    directory) need to set up very specific configurations before compiling some of the
    utility programs, and therefore these scripts check to see if the CATALINA_DEFINE
    variable is set - (if so) they refuse to run, because the settings could interfere with
    the operation of the script. To run these scripts, first unset the CATALINA_DEFINE
    variable, and then specify the target on the command line &#8211; e.g:
    build_all HYBRID
    Loading Programs
    For LMM programs, the simplest way to load a program (assuming your platform has
    a suitable serial or USB interface, and it is connected to your PC, and the Propeller
    is powered up) is to use the Payload serial loader. Just enter a command like:
    payload hello_world
    Payload will locate the Propeller automatically. You can also load programs into
    EEPROM, by including the &#8211;e command line option:
    payload hello_world -e
    Before we can load XMM programs, we must first build some Catalina utilities for the
    platform we want to load. To do this, go to the Catalina utilities directory, and enter
    the following command:
    build_utilities
    This is an interactive batch program which will ask you questions about the Propeller
    platform you intend to run the programs on.
    So I think the two batch files to run are build_all and build_utilities
    I'm still not sure about xmm.binary - it is not in the /bin folder but I suspect that one of the above batch files might create it.
    Ultimately what I'd like to write is a step by step guide specifically for XMM programs/boards. These are different to the standard setup. (I see Rayman has done this just in the last few hours! http://www.rayslogic.com/Propeller/Products/FlashPoint/Catalina/Catalina_FlashPoint.htm)
    Step 1 is to get an XMM program compiled in version 3.3 from the command line. Then look at code::blocks. brb
    edited 2011-10-17 19:28
    Dr_Acula wrote: »
    Hi Ross,
    Hi Dr_A,
    I'm sure I've said this several times now :smile:
    XMM.binary is not included in the Catalina distribution because it it platform-dependent. You have to build it yourself. You can do this in either of two ways:
    From the Catalina Command Line:
    build_utilities
    From Code::Blocks:
    Tools->Build XMM Utilities
    In either case, the correct XMM.binary will be built and copied to the bin directory, where Payload will find it automatically. You do not need to copy this file anywhere else. If you have copied it elsewhere, you are probably best off deleting all the copies.
    Note: The build_all script (in the utilities folder) is a third way of doing the same job - but it does not walk you through the various options step-by-step - you have to know exactly what to specify on the command line.
    Ross.
    edited 2011-10-17 20:06
    AHHHHHH. Thanks Ross. That fixed the problem:) I spy a beautiful little "Hello World" message.
    edited 2011-10-17 20:15
    Great! Now you have no excuse for leaving! :)
    Ross.
    edited 2011-10-17 20:21
    @Ross... Yeah, i am stuck with guys a little longer, haha... Now i have to do stuff like setting I/O pins, flashing LEDS, declaring variables. Is there more info i could find about basic I/O functions?
