Student project - Help needed! What components to use for robot?
Hi Everybody,
We are a group of 13 persons from the University of Applied Sciences Northwestern Switzerland. We all just started studying, so our knowledge is quit basic. As a student’s project we have to join a competition. By April we are supposed to complete a computer controlled robot in the size of let’s say 500-700 mm that can do several movements: dance, greet, relax, cheer and do one additional special move. The project name is darwin21.org (unfortunately is all in German).
Therefore we planned to construct a body with arms, legs and head. Each arm or leg has 3 axis. Additional we have to control another 2 axis. So in total it will be 14 axis. This means we have to control and program 14 servos.
In general the movements are fixed programmed and visitors of the exhibition can choose from a touch panel what the robot should do. Additional the visitor can use 6 slide bars to control arm and legs individually. The System is recording the movements and afterwards playing them. The robot should also be controlled via web page. A centralized system can send 6 defined commands (probably in C) to all the projects to have them simultaneously run one of the specific movements (e.g. have them dance all at the same time).
The darwin21.org project organization is providing us a display cabinet, a industrial standard computer (probably running WinXP) and a touch panel.
We are thinking about of using the following components:
14x Parallax (Futaba) Continuous Rotation Servo
1x Parallax Servo Controller (USB)
Do you think that is realistic and can be done with those components?
We would appreciate any hints!
Thanks.
Florian
Thanks.
Florian
Pi Guy
Thank you for your quick reply. We are absolutely free in what to choose. Our first concept is using a digital card from national instruments that is plugged into a computer. This solution is very expensive. The controller without servos is around 2000 US$. I think this is much too expensive. So I checked out Parallax.
The robot is doing simple things, just moving his arms and legs. We can built it lightweight and it is not required that it can stand by its own. It's a simple puppet. So I guess the servos with Torque 3.40 kg-cm should be o.k. Alternatively we found quit strong servos, but those are operating at 6 or 6.7 Volts.
We control the robot with a computer or the suggested Propeller micro chip, we are free.
But we require the following features:
1. User can choose from a touch panel (C# programmed, this is predefined already, but we haven’t seen it yet) out of the 6 preset movements.
2. A main controlling unit can send a C-Command to each computer to have all projects to do the same preset movements (e.g. dance).
3. The visitor can play with a potentiometer (6 slide bars) (HW is provided), have the computer record it and later play it by the robot.
4. We plan to control light (e.g. color changing while dancing)
5. Maybe we will use some sensors (e.g. turn the robot in direction where the visitor is standing)
6. Maybe it must be controlled via a web interface.
Is it better to use a Propeller micro chip?
Florian
The BOE-Bot can be an initial "stand-in" device for the 14-servo 'puppet', letting you 'drive it around' by command (instead of the puppet movement). This would let you debug your C-side / WinXP code using a serial port and the BOE-Bot.
The BOE-Bot would also give you a "real-time" BS2 processor to use to test and verify servos when it comes time to build your 'puppet'.
For $200 or whatever, it's a very small price to pay compared to the value and proofs-of-concept you'd get out of it for the rest of your project.
Oh, and for maximum flexibility, get the "Serial" version, not the USB version.· If you don't HAVE a "serial" port, get the separate USB to Serial adapter.· This is a MUCH more flexible and reusable arrangement than the USB-BOE-Bot.
Post Edited (allanlane5) : 11/5/2008 2:12:37 PM GMT
Parallax's PINK internet interface might be a good way to provide this. The Propeller is capable of providing an internet interface (see the YBox2: www.deepdarc.com/ybox2/), but it would be much simpler to use a separate device to provide this. You could use two Propellers, one to control the robot and one to provide the internet interface.
Post Edited (Mike Green) : 11/5/2008 4:33:58 PM GMT
