Newb looking to make a MIDI controller.
So, I'm rather new to this whole microcontroller thing but I've been researching for about 2 months. I'm a musician and I'm looking to turn an old supernintendo controller into a midi controller. I was originally looking at the basicstamp, but after scouring the forums I came across a couple threads that lead me to believe that propeller may be a better option.
The goal of the project is to send MIDI data out by pressing the buttons of the Supernintendo controller. I'd like the MIDI data to be sent through usb(so I'll probably using the Propstick USB?). I also want all the boards,controllers, and other electronics to be inside the Supernintendo controller.
So here are my questions,...
1. Is my idea feasible with propeller?
2. Is the project too far out of a relative beginners range?
3. I plan on using this kit, http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/ProductID/506/List/1/Default.aspx?SortField=UnitCost,ProductName. Would that be all I need?
4. What about power? Would I need some type of powering unit or can I power it using the usb cable?
Thanks in advance!
Thanks in advance!
welcome to the propeller-forum !
Your first two postings are really good! I want to explain about that:
- you give an overview about your project
- you give somehow detailed informaion about your skill-level in electronics and programming
- you are asking questions like they come into your mind
This all is VERY good
Now to answer your questions:
the propeller can do that
If it is out of the range of a beginner depends on the complexity what you want to do.
ALL propeller-kits are connected via USB to a PC. Really ALL of them. Why this? because nowadays PCs have no more serial COM-Ports.
All Propellerboards work through a chip that converts from USB to a serial COM-Port. Some of the kits have this chip mounted on the board
(like the propstick USB or the PPDB) some of them have an extra adapter. All these USB-devices create a virtual-COM-Port on the PC
So in the end you have LOGICALLY a V.24 serial connection where the data goes PHYSICALLY through an USB-port.
As you are a real beginner I would recommend using the Propeller Education Kit - 40 pin DIP Version
With the Propeller Education Kit - 40 pin DIP Version If you damage the prop-chip you can replace it for $8.
On the propstick USB you have to send it to parallax trying to repair it or buy a new one for $100
The prop-chip is pretty robust but there are limits voltage and current should stay inside to avoid damages.
I guess you want to use the propeller to create the MIDI-signals and send them to a PC (or some other MIDI-device?)
You can interface the propeller almost DIRECTLY to a MIDI-input.
This is much much easier than trying to make the prop-chip acting as a USB-device himself.
Another input-path might be to have an extra interface MIDI-2-USB but here the prop-chip still creates MIDI-signals for a standard MIDI-input
Feel free to aks as many questions as you like.
best regards
Stefan
My intentions are to send the data to ProTools.
So, what is it you want to send to and what data do you want send?
Gary
I am looking to convert a number from 1 to 120, to, a midi signal containing notes that compare to the number. So the higher the number the higher the note.
In the end i just want to say: if the number is 48 play note "F#" (for example)
I don't need a very wide range. 17 to 20 notes is fine
I seriously hope you can help!
Hi Botdocter
It should be as simple as opening serial object and sending out some values.
Try this:
CON MIDI_OUT_PIN = 0 'MIDI out pin MIDI_IN_PIN = 1 OPEN_DRAIN = true 'if using the standard MIDI output circuitry TX must be open drain INVERT_TX = false 'change if required BASE_OCT = 0 'can go down to -2 or up OBJ ser : "FullDuplexSerial" VAR long onems PUB main | n, mode mode := 0 if INVERT_TX mode |= 2 if OPEN_DRAIN mode |= 4 ser.start(MIDI_IN_PIN, MIDI_OUT_PIN, 31250, mode) waitcnt(cnt + clkfreq * 3) onems := clkfreq / 1000 repeat repeat n from 0 to 60 send_note(n, 500) waitcnt(cnt + clkfreq * 10) PRI send_note(pitch, duration) 'send NoteOn message ser.tx($90) ser.tx((BASE_OCT + 2) * 12 + pitch) ser.tx($40) 'wait for a while waitcnt(cnt + duration * onems) 'send NoteOff message ser.tx($80) ser.tx((BASE_OCT + 2) * 12 + pitch) ser.tx($40)If you cannot get it to work you can try inverting the output.
It's assumed that you're using two 220 ohm resistor following the circuit indicated in the MIDI specifications.
Alessandro
About the wiring setup for the midicable; where can i find this info? i have looked but have not found any wiring setup for propeller.
http://forums.parallax.com/showthread.php?118144-MIDI-Output-%28Via-USB-or-MIDI%29&highlight=Midi+Schematic
Refer to the lower section of the circuit:
the inverter marked with "A" should be an open-collector (or open-drain) type.
You can omit the first inverter, and compensate by the inversion flag in the software.
You can omit both, as long as the MCU you're using has open-drain mode (as in our case).
So in the end you only need two 220 ohm resistors, one from +5V to pin 4 of the DIN connector, and one between the prop tx pin and pin 5.
Pin 2 of the connector goes to ground (only on TX side, note that is disconnected on the MIDI in side to avoid ground loops).
If you're driving very long cables, or if you want to keep the Propeller fully safe against output shorts, you'd better use an NPN BJT (or better a 74HC07 gate) to buffer the signal.
For BJT connection, look at the second diagram (again the inverter gate can be omitted and compensated in software).
P.S. the schematic by Ariba that Bob linked is even simpler, and is perfectly fine with 3.3V supply only, as long as you double check the wiring.
