MMA7455 with BS2PE problems
Hi,
I am trying to test out an accelerometer with a BS2pe.I have downloaded the sample program that is given and connect the wires accordingly, but the values i received is not constant even when stationary.
Sometimes, i get a -1 values for all axis.
Also, i am clueless to where should i connect the CS pin.
So what is the raw data type? and how to change it to a g value.
THANKS
