Knowledge Management Software
I'm looking into setting up a knowledge management system for my company.
The idea is to have a repository of information, code snippets, sample drawings, documents, etc. that could be searched and updated by employees.
So far it is looking like twiki or foswiki might be good candidates.
Does anyone have any suggestions or success/failure stories to share?
Thanks in advance,
C.W.
Thanks in advance,
C.W.
I thought this subject might have be of interest since a lot of folks on here seem to run small shops where there is a lot of technical knowlege that would be good to capture for future use. I'm at the point were I need to add staff and I want setup a good foundation for sharing information and best practices.
C.W.
I had been running an old HP tower internally in the company 24x7 for 3 years without any problems (apart from some power outages in the building) with an active community of around 2000 people (the company itself is around 100.000 people and they now mandate the use of Sharepoint, which I do not like, and I recently migrated all content to that)
If I would set this up again I would look for something with GIT version control as a backend instead of a SQL based backend. The GIT Server can run on the same machine. This would fit well in the developers workflow.
I've been looking at WIKO (http://www.dtic.upf.edu/~dgarcia/wiko/) basically because it is python based
Sharepoint is another commonly used solution, although I agree with rosco_pc and don't care for it. It requires more IT involvement for creating solutions which increases the resources required to get a project in place. It can be much more powerful depending on the version and modules you purchase, but does require true programmers to be involved in many cases.
I have also played around with Wordpress and you might be able to find templates that could be used as collaboration points.
Thanks for the suggestions, I'll take a look at them.
C.W.
