Filtered PWM DAC to provide +/- 10v
Mickster
I plan to have a single 24VDC supply from which the Prop will be powered through regulators, etc.
A +/-10v analog output is required to command an industry-standard servo-drive.
Question: It is common practice to utilize a dc-dc converter to provide a +/- 12v supply to the op-amps for this type of circuit. Does anyone know of a reason why a 'rail-splitter' (virtual ground) would not be suitable for this application.
Thanks and regards,
Mickster
Thanks and regards,
Mickster
I've found this V7812-500/102-1712-ND little point of load DC-DC converter useful for generating negative voltages. Most buck converter modules can be abused as inverting regulators, but this series lists this use in the datasheet! They also have low noise, and sink current almost as well as they source current.
Lawson
Use Lawson's things to get +/- 12 V. Then, use regular regulators to get +/- 5V and +3.3 V.
Use a digial pot, like DS1267 to give you an output signal between -5 and +5 volts.
Then, use a regular opamp (powered by +/- 12 V) to double that to -10 to +10 volts...
Lawson
