Measure Capacitance — Parallax Forums
Measure Capacitance
mynet43mynet43 Posts: 644
edited 2011-10-06 22:11 in Propeller 1
I'm sure this has been covered before.
Is there code/circuit available to measure the capacitance of an unknown capacitor?
I assume it would measure the charge time, and convert it. I can probably figure it out, but I'd rather not re-invent the wheel.
Thank you for your help.
Jim
    edited 2011-10-06 10:17
    Read the section of the BASIC Stamp Syntax and Reference Manual on the RCTIME statement. This measures the charge or discharge time of an RC circuit and there's a description of the theory and sample programs. There are a variety of techniques using the Propeller to do the same thing. The simplest is to use the RCTIME routine in the BS2_Functions object from the Propeller Object Exchange.
  • mynet43mynet43 Posts: 644
    edited 2011-10-06 10:26
    Hi Mike,
    Thank you for the quick response.
    This is exactly what I was looking for.
    Jim
    edited 2011-10-06 12:09
    mynet43 wrote: »
    Jim
    Download or find the Prop ed. kit lab manual V-1.1. Check out the section on counters page 122 on measuring the rc delay of a network on one pin of the prop chip. (I have NOT tried this because I tend to find/learn/use what I need in a JIT manner. Like everyone else or my own ADD eh, who knows?) But the example uses finding the unknown value of R on a potentiometer and a known cap value. Seems that once the delta t is known it is just math from there on. Use a fixed known value of R and go from there.
    Frank
    edited 2011-10-06 12:32
    Thanks all!
    I think you filled in all the holes. I'm off and running.
    Jim
    mynet43 wrote: »
    Thanks all!
    Jim
    Hey Jim,
    I just noticed a goof in the prop Ed kit (v1.1 and v1.2) that could potentially mislead you and others on the RC ckt as shown. I am going to put it in the main part of the forum. P123 (v1.1),p127 (v1.2) manuals
    Frank
