How to combine two programs into one? Please help - Thank you
Anyone know how to combine these two programs into one program so it can be download to the BS2e ?
Program 1:
' {$STAMP BS2e}
' P4 -> ULN2003.1, ULN2003.16 -> Phase 1 (Black)
' P5 -> ULN2003.2, ULN2003.15 -> Phase 2 (Orange)
' P6 -> ULN2003.3, ULN2003.14 -> Phase 3 (Brown)
' P7 -> ULN2003.4, ULN2003.13 -> Phase 4 (Yellow)
[ I/O Definitions ]
Phase VAR OUTB ' phase control outputs
[ Constants ]
[ Variables ]
idx VAR Byte ' loop counter
stpIdx VAR Nib ' step pointer
stpDelay VAR Byte ' delay for speed control
[ EEPROM Data ]
Steps DATA %0011, %0110, %1100, %1001
[ Initialization ]
Setup:
DIRB = %1111 ' make P4..P7 outputs
stpDelay = 10 ' set step delay
[ Program Code ]
Main:
FOR idx = 1 TO 1//4 ' one revolution
GOSUB Step_Fwd ' rotate clockwise
NEXT
PAUSE 1000 ' wait 1/2 second
GOSUB Step_Fwd1 ' rotate counter-clockwise
NEXT
GOTO Main
END
[ Subroutines ]
' Turn stepper clockwise one full step (7.5 degrees)
Step_Fwd:
stpIdx = stpIdx + 1 // 4 ' point to next step
GOTO Do_Step
' Turn stepper counter-clockwise one full step (7.5 degrees)
Step_Fwd1:
stpIdx = stpIdx + 1 // 4 ' point to previous step
GOTO Do_Step
' Read new step data and output to pins
Do_Step:
READ (Steps + stpIdx), Phase ' output new phase data
PAUSE stpDelay ' pause between steps
RETURN
Program 2
' RelativeHumidityReading.bs2
' Displays relative humidity in the Debug Terminal or the Parallax Serial LCD.
LCD PIN 0 ' Serial output to LCD
time VAR Word
humidity VAR Word
LcdBaud CON 84 ' Baud rate of LCD
RHconstant CON 12169 ' Relative Humidity Constant * 10
LcdCls CON $0C ' Clear LCD (use PAUSE 5 after)
LcdCR CON $0D ' Move pos 0 of next line
LcdBLon CON $11 ' Backlight on
LcdBLoff CON $12 ' Backlight off
LcdOff CON $15 ' LCD off
LcdOn1 CON $16 ' LCD on; cursor off, blink off
LcdLine1 CON $80 ' Move to line 0, position 0
LcdLine2 CON $9A ' Move to line 1, position 5
HIGH Lcd ' Setup serial output pin
PAUSE 100
SEROUT Lcd, LcdBaud, [LcdOn1] ' Initialize LCD
PAUSE 250
SEROUT Lcd, LcdBaud, [LcdBLon] ' Turn Backlight on
PAUSE 5
SEROUT Lcd, LcdBaud, [LcdCls] ' Clear LCD
PAUSE 5
DO
HIGH 7
PAUSE 1
RCTIME 7, 1, time
time = time * 10
humidity = (time - RHconstant) / 24
' Debug Display:
DEBUG HOME, "Relative Humidity = ", DEC humidity, "%"
' LCD Display:
SEROUT Lcd, LcdBaud, [LcdLine1, "RelativeHumidity",
LcdLine2, DEC humidity, "%" ]
PAUSE 100
IF humidity < 40 THEN
HIGH 13
PAUSE 2000
IF humidity > 40 THEN
LOW 13
PAUSE 1000
ENDIF
ENDIF
LOOP
Thanks so much
Program 1:
' {$STAMP BS2e}
[ I/O Definitions ]
[ Constants ]
[ Variables ]
[ EEPROM Data ]
[ Initialization ]
Setup:
[ Program Code ]
Main:
NEXT
NEXT
GOTO Main
END
[ Subroutines ]
Step_Fwd:
GOTO Do_Step
Step_Fwd1:
GOTO Do_Step
Do_Step:
RETURN
Program 2
time VAR Word
humidity VAR Word
PAUSE 100
PAUSE 250
PAUSE 5
PAUSE 5
DO
HIGH 7
PAUSE 1
RCTIME 7, 1, time
time = time * 10
' Debug Display:
' LCD Display:
PAUSE 100
HIGH 13
PAUSE 2000
LOW 13
PAUSE 1000
ENDIF
ENDIF
LOOP
Thanks so much
Maybe you're not clear on how to run these from different banks?
At long last (!), they put a link to that great N&V article along with the other resources on the BS2e page --
http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol3/col/nv87.pdf
Thanks guys,
Im trying to run a stepper, read a humid sensor and control a water pump from the reading of humid sensor. What codes I should use when I combining them?
http://www.savagecircuits.com/forums/showthread.php?145-Episode-5-Merging-Programs-Part-1-of-2
http://www.savagecircuits.com/forums/showthread.php?146-Episode-6-Merging-Programs-Part-2-of-2
Thanks so much, I don't know why the program below only run the Main- End , but not the DO LOOP ? Anybody has any idea?
' {$STAMP BS2e}
' {$PBASIC 2.5}
[ I/O Definitions ]
[ Constants ]
[ Variables ]
time VAR Word
humidity VAR Word
[ EEPROM Data ]
[ Initialization ]
Setup:
PAUSE 100
PAUSE 250
PAUSE 5
PAUSE 5
[ Program Code ]
Main:
NEXT
NEXT
GOTO Main
END
DO
HIGH 9
PAUSE 1
RCTIME 9, 1, time
time = time * 10
' Debug Display:
' LCD Display:
PAUSE 100
HIGH 13
PAUSE 2000
LOW 13
PAUSE 1000
ENDIF
ENDIF
LOOP
In this case, what should I do to combine these two programs? What LOOP I should try? Thanks
