Plx-daq
Hi,
I'm new on this forum, but not new into the world of robotics.
Only, I used Arduino. I hope i can use this forum...
At our school we used Arduino UNO board to measure some sensors. To put the values in Excel, i've download a tool from Parallax, PLX-DAQ. Original developped for Basic Stamp.
And there are the questions about.
I try to modify this Excel macro, but don't exactly understand how this works.
We want to make a button which takes one sample from the arduino-board. When I connect now, the communication opens and arduino keeps going on with sampling.
But our new button must take one sample, go to the next row and wait for the next button-click.
I don't know where we must change. In the arduino-sketch or in the VBA-code of this macro.
Anyone experience with it? Or solutions?
Kind regards,
Johan
Kind regards,
Johan
Mike, the reason I look at this forum is that plx-daq is distributed by paralax. I contacted Selmaware (the maker) and they gives their permission to modify (the layout of) the macro so that it will be suitable for pupils in age of 12-14 years.
So i think: perhaps there is anyone who knows this macro, who knows Basic Stamp and who knows Arduino. Or is this forum only for non-Arduino people? Then I leave it as soon as possible... :-)
Sylvie, I try it out. But I have to translate the Basic Stamp code (in the helpfile) to Arduino. And that gives some trouble. But your explanation is clearly. Thanks.
Gr.
Johan
The forum guidelines state:
Posting non-Parallax related topics:
Although this forum is intended for ongoing discussions about products designed by Parallax Inc, other topics can be created; however discussions regarding outside products or programming may not receive any technical attention.
So, although you can certainly ask questions related to non-Parallax microcontrollers like the Arduino, the answers you may get will be mostly in terms of the Stamps or Propeller. I've used an Arduino, but I'm not an expert nor do I keep examples or documentation of its use the way I do with Parallax products.
Similarly with PLX-DAQ. I've never looked at the macros involved. I understand how it works and I can advise people on how to use it, but, if you're going to modify the macros, you're on your own.
I'm not sure why you have to modify the macros or even look at them. From your limited description, PLX-DAQ is more than adequate for the task as it stands and 12-14 year olds, when given good specific examples, are capable of using it.
The macros look at input from the processor. As the Control Directives page of the help file says, .
So your Arduino will send a string out the serial port beginning with the control directive you want the macros in PLX-DAQ to run (DATA, LABEL, CLEARDATA, RESETTIMER, SET, GET, etc.), followed by the parameters and variables that go with those directives (for example, the DATA directive wants the data, separated by commas). Finally, each string you send must end in a CR. I believe that one of the Arduino serial output commands automatically appends CR/LF, so that should work (perhaps "println()"? "writeln()"?).
The overall syntax for Arduino is different from that for Stamp, in that you declare (and name) a serial port, and then explicitly open it, and then use that name in all your serial reads and writes, whereas in PBASIC you identify the serial port, baud rate, format etc. each time you do a SEROUT or SERIN. Read the Arduino examples on the Arduino site to get their syntax down pat.
As long as your Arduino sends the same directives, parameters, and data we're sending from Stamps, the PLX-DAQ macros won't know the difference.
Problem is solved. It was only change the Arduino sketch and the Excel-sheet, as Sylvie said.
Gr.
Johan
