Measuring SPL
Franny
Hi, I need to be able to measure the level of a sound coming out of a mic preamp (at line level) It doesn't have to be high quality, all I need is a fairly accurate sound preassure level reading.
There is a free iPhone app called JL Audio. It will measure SPL. I am sure there are others.
If you want to measure the level just after the preamp - that is some kind of level - but it is not Sound Pressure Level.
Right. I'm not sure if you are agreeing or making an argument.
Measuring the voltage after the preamp may give you an idea of the expected SPL, in the same way that measuring the voltage to a motor will give you an idea of the speed of the motor.
your meter may be right for a 100W amp feeding some book shelf speakers but a pare of ear buds would read the same in the meter bur not in real life ............
you want a VU meter???
http://http://www.national.com/mpf/LM/LM3916.html#Overview
no offense to the BS2 but there are COTS chips that are really good at this ..
If you do use a BS2 and a ADC be shure to cal it!!!!!!!!!.
Peter
http://www.parallax.com/ProductInfo/Robotics/ScribblerRobotInformation/ScribblerRobotDownloads/tabid/458/Default.aspx
