What kind of video are you using
LoopyByteloose
Hello,
I am curious what everyone is using.
1. VGA
2. NTSC/PAL
3. LCD
4. Other
This would be your first choice, not all you are using.
1. VGA
2. NTSC/PAL
3. LCD
4. Other
I need to do more with video!
Frank
It provides big bright letters that are easy to read through the smoke clouds billowing out of my prototypes.
I use composite monitors and Raymonds LCD screens equally, and I also use serial console.
For quick development I use composite, 3 pins, just works. I use the serial console for debugging as well as video.
But I love the Raymond LCDs for their bright colors in the final development stages. I've shared a bunch with friends - they are amazed. Though as with myself, most are time challenged.
Another poll should be "Which tools do you use to debug your code" and ask folks to elaborate, we could probably learn a lot!
Actually, years ago when I first went to work for Siemens Medical Systems, we had a trick of putting a vertical freq sawtooth into one of the scope channels, and the composite video from a videomed N/H/C into another to get a sort of quick and dirty display. Gray matter just does not seem to be able to recreate it for now.......
Frank
Hanno
For general debugging, I use PST. Once the code is up and running I usually use a NTSC display. As I stop to count displays around me, I find Rayman's LCDs (I recently purchased a few more of his breakout boards) are a close second to NTSC monitors.
With my VGA project and projects using Rayman's touchscreens, I use a second Prop as a graphics coprocessor.
Duane
Anyway, in fact I use serial and PST the most. I did prefer VGA but these days I have a nice 4" composite LCD so I prefer NTSC/PAL one I go past Serial/PST. I only use text if that helps.
The good news is that as I often use the GRAPHICS driver object, it is compatible with the TV object AND the VGA object,
and therefore I can code and construct projects with connectors for both types of display, so whichever is handy is usable.
Joke of the day: When pigs fly, where do they land? At an airport, just like we do.
My cherished PAL/NTSC CRT 9" monitor's focus went a while ago, and so it had to go and meet it's recycler.
Frankly, I thing the OBEX should have sub-directories for these different video dependencies. A lot more would get done if users didn't have to read through a mixed list. As it is, searching VGA as a keyword brings up quite a bit more than just the 'foundation objects'.
Maybe, one day there might be an object that toggles between the VGA and NTSC during compilation. That might be handiest.
However, I finally sat down one day and wrote a few VGA drivers for myself, and I now have the 18 line by 43 char ROM font driver which does 2 colors plus background per line, plus inverted text, and as many extended bitmap characters as I want, and the output is much clearer than NTSC and the color selection is much cleaner. I've also been told by my sales associates that the extra $200 for a VGA capable monitor really isn't an issue for most of what I do, so from now on I'll probably be using mostly VGA.
John Abshier
I'd do what Hanno is doing if I were smart enough.
Go Brewers!
Edit: my first of those car reverse cameras arrived yesterday, and it works great. What a bargain!
-Tor
I will try to correct the typos. It seems in the past few years that my fingers have begun to have independent streaks. In Others, it should also say reply not replay. But I couldn't seem to find a way to edit out the typos after submission.
This all is making me look like a rather poor English teacher.
