Search for code in OBEX
DaveJenson
I'm trying to find the code for JM_BAM8 that I saw mentioned. I'm having a devil of a time finding any useful results from the OBEX search engine.
If I search for "JM_BAM8", I get no results.
I search for "jm", no results.
I search for "mcphalen", no results.
I search for "BAM", I get one result (jm_BAM_rgb).
Am I doing this wrong? Any suggestions?
http://www.google.com/search?q=JM_BAM8+Parallax&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a&safe=images
This object uses accumulator-divider modulation so you have no control of output frequency (which varies with duty cycle). That is to say that this is only good for LEDs and charging RC circuits, not running motors.
Thanks. Works great with forum posts, but doesn't search OBEX, which is what I am trying to do...
Thanks for the reply and the code. It doesn't answer my basic question of how to effectively search the OBEX... I have been using BAMSingle.spin for a while and was really interested in the BAM8 code.
Thank you! That will work.
(Now how do I mark this as solved??)
