WiFi via Single Board Computer
Bill Chennault
All--
Now that the WiFi can has been kicked down the road, I am looking for other solutions. My robots tend to be relative large and with battery power to spare. I don't want a display or keyboard on the robot. So, XP/WiFi enabled single board computers appeal to me. Do you have a recommendation?
Thanks!
--Bill
Thanks!
--Bill
BeagleBoardXM is a popular Linux board from Digikey now. It may be able to add wifi easily and certainly will support quite a bit -- SPI, RS232, RS485, and I2C. I am not sure how to add the wifi to it, but a USB link might be the most painless.
While I love the Propeller for dedicated control of motors and sensors and such - having a file system and broader communications with the real world seems to indicate some kind of OS. And of course, we don't have much choice of OSes if we want room to play - it is a three flavored world, Apple, M$, or Unix/Linux.
Recently, I spent a lot of time reading up on SSH (secure shell) and that combined with the wifi would make your communications pretty much private.
For an XP/Wifi solution, you might as well consider a small netbook as a complete package. It is difficult to buy separate components for less that the $300USD for the package. Try EBay. One problem with an XP solution is that is it near the end of its useful life, so manufacturers of SBC have to re-evaluate the worth of carrying inventory or going to W7 or W8.
XP or any Windows is in a bit of a conflict with what you are doing as you cannot remove the GUI software from Windows, but in Linux you can leave it out in an application that doesn't require a monitor and/or keyboard. In other words, when space is at a premium, Linux has the ability to do more in less space.
Perhaps GHI has smaller cheaper WIFI set ups than the Cobra. I have not checked.
I'm wondering if its easy to use just the WIFI extender board with the Prop directly. It has SPI interface.
Or have a search for Zero-G WIFI boards.
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=2884
I've got a couple of their PICtail Wi-Fi boards. They work very well with the PIC32 and 16-bit PICs.
If you go the Linux route, the Chumby hacker board is ARM based, but comes with a development tool chain. It has host USB ports and can use a USB WiFi module. All together this should cost you less than $100. Plus it has some hardware interface ports built in. I've been really tempted by it.
There are others Arm/Linux boards like Gumstix as well.
They generally run about $100 and are loaded with H/W & S/W.
NetGear (and others) make wifi devices that output to an ethernet port. (around $30) that are DC powered. (5 V I think) Maybe that is a cheaper way to go. Combined with WIZ812MJ Ethernet SPI/Bus Module from Parallax would give you a cheap solution without any hardware developement.
Jim
http://www.amazon.com/ZIPIT-All-Wi-Fi-Messenger-Black/dp/B00115PR2O
Mine has Debian installed now. WIFI works a treat. With a couple of wires soldered on the back you have a serial link to the Prop.
But others are coming up with alternatives I haven't been aware of.
http://www.linuxtoys.org/chumbot/chumby_as_robot.pdf
Here's a video of a walker built using one:
The Chumby One is discontinued, but the hacker board is basically the same board as the Chumby One (minus built in WiFi). Most of the information should work with the hacker board which is still for sale. But Chumby One's show up on eBay regularly because people are upgrading to the new 8" model.
The Insignia Infocast is even cheaper and uses the Chumby design, but is made by a different manufacture. I think it is also missing the slot for the internal battery which would complicate power a bit.
http://pandaboard.org/content/resources/getting-started
First impressions are I like this more than the BeagleBoard. Again, Digikey sells these, maybe Mouser as well.
It's a nice board. I wish it had a non-OTG USB port as well though. That's the one thing it's missing, otherwise everything is there.
-Tor
From the latest Pandaboard documentation (pg 12 Feature Chart)
HS USB 2.0 OTG Port - Mini-AB USB connector, sourced from OMAP USB Transceiver
HS USB Host Port - Four USB HS Ports, up to 500mA current out on each, two to onboard connectors, two to expansion connectors
What type of USB support were you looking for?
I'm not sure what they really mean by '10/100 Ethernet & 2xUSB' though - what kind of connector would that be? It looks like a single USB connector in the photo.
-Tor
This board looks pretty darn capable. I'm going to start reading up about Linux on it and start saving money for a present for myself!
I can use several popular distros of Linux - Ubuntu, Angstrom, and Android - plus others. I'd go with Ubuntu as I have been using it for three years now. In fact, my Toshiba netbook has Ubuntu and the total footprint is still only a bit less than 4Gbytes - software and data. I think an 8Gbyte SDcard is a lot of storage.
If you are going to get involved in Linux, understanding a bit of Unix is quite helpful as well because all the low level stuff originated in Unix. New devices - like an SPI interface are created as a file the /dev directory (in fact everything is a file in Unix/Linux). I/O is simply divided between block transfers (for mass storage) and byte stream for keyboards, sensors, etc.
And there are tons of utilities for working on custom projects with Shell scripts, Python, C, or whatever. If you want Forth, there is gForth and pForth in Ubuntu.
It looks like the idea of a WiFi enabled robot is very popular. I wish there were a good way to do it without resorting to a laptop or SBC.
--Bill
You might have better luck with ZigBee or Bluetooth, but having wireless without a seamless interface is limiting. This has both the Bluetooth and the WLAN. This looks like I could put it atop a BOEbot and it has a camera interface provided as well.
The documentation has the same street address as the BeagleBoard, so it looks as though this is a spin off of that project.
It's a terrific looking board. If I didn't own a Beagleboard C3 already I would get this one. Maybe if I can find a permanent project for my Beagleboard.. then I'll have an excuse to get another test/hacking board. The Panda looks like a much better upgrade than the Beagleboard Xm - the latter went to microSD, for example, and can't compete with the Pandaboard w.r.t. other interfaces. The latter seems to have just about everything possible.
-Tor
WiFi...
The search continues.
A bit of envy. I hate waiting for back orders. I am even wondering if Digikey will ever deliver my PandaBoard. I see that Mouser has them in stock, but a higher cost.
Internally it has a Tx/Rx header that I can run out through the case and interface with a microcontroller. Since it is a 3.3 volt device it will work fine with my propeller platform, but I'll need to use my level shifter for my BS2e or Arduino.
I want to establish a Wi-Fi connection between my android phone and MRF24WB0MA Wi-Fi module without router.
Is it possible? or Is there any other Wi-Fi module has the same ability to connect to a smartphone without the need of a router?
Could you please give me a solution in details.
Unfortunately I have no suggestions for your problem. On my Galaxy S I can set it up to be a mobile access point such that my lap top connects over wifi and can use the internet via 3G. That is to say the phone becomes a wirelss router. Problem is it does not really allow the laptop (or whatever) to interact with the phone itself.
Whils we are here I would like to add to the suggestions re: Wifi via SBC.
One can now use the 25 dollar Raspberry Pi ARM board running Linux with a USB WiFi dongle. Connect that to your Prop via the Pi's UART port and there you have a cheap and simple Wifi adapter for the Prop with the added bonus of filesystem on SD card. Lot's of extra processing power. HDMI video, audio and lots of Linux goodness.
Thank you for your reply.
