Microscope for SMT soldering?
RDL2004
Does anyone here use a microscope for SMT soldering? If not a real microscope, what kind of magnification device do you use?
I have one of those task lights that has a circular fluorescent tube with a 5x magnifier in the center, but it just isn't cutting it for soldering the surface mount stuff. It doesn't really magnify enough and it's hard to keep it lined up so that the view isn't distorted.
I'm seriously looking at this microscope: http://www.ebay.com/itm/350130363543
It looks like a good deal from a reputable seller, but I'm reluctant to spend that much money on something that may not get much use. I realize that one on a boom type mount would be better, but those are way out of my price range. For what this one is selling for, I may just go for it and re-sell it if it doesn't work out.
Does anyone have other recommendations or suggestions? or even just comments...
http://www.lakeland-microscopes.co.uk/stereo.html
The mechanical and optical quality are surprisingly good, given the low price. It looks similar to the one you mentioned.
Field of view and a working distance over 3" are key things to look for in a scope for soldering. I have also seen people use the digital USB microscope cameras for soldering as well. We have a small one, but it's lowest power setting is 100x which is too high for soldering use. I know someone that uses one of those kids USB microscopes to solder; something like the Eye-Clops. He picked it up at a thrift store for less than $10.
If your digital camera has the ability to output NTSC or HDMI video, you can mount it on a tripod, put it into macro mode with a zoom lens, and solder with your TV as your aid. I have not done this for soldering, but for an IPC training, I once brought in my Canon T1i and used the live HDMI output with a 46" LCD TV in a conference room. Worked out very well.
I think the ideal tool for this would be a surgeon's or dentist's magnifier:
They're not cheap.
To inspect my work after the fact, I use either the 5" arm-mounted magnifying lens or a higher-power loupe.
Look on that one.
USB Digital Microscope 200X
(You can't see it, but there's a lens that swings down behind the big one)
This one gives me 1,8x, 2,3x, 3,7x and 4,8x magnification.
A higher magniication would be nice, but as I don't plan to do smaller than 0805, it isn't an issue yet.
then an additional high power magnifier for fine tuning.
I don't like the head mount magnifiers because they mess with depth perception. I suppose a real expensive one might adjust for this, but none of the ones I have tried feel natural to the eyes, like what Leon's suggestion will.
I echo Andrew Williams' concerns about the mount being in your way. I think it makes that model useless.
I bought a commercial 1.. 40X zoom binocular microscope with the mount the "correct" way many years ago, and it has served me very well. At times there is nothing else that will do the job. The 3D vision you get with the binocular is an absolute "must".
The price quoted is very attractive. I paid well over ten times that before ebay existed.
Find one the right way around, with zoom of at least 20X, and you'll be very happy.
Cheers,
Peter (pjv)
I'm looking for a new soldering iron for use exclusively with my surface mount chips - I have a Velleman and I can't get a tip small enough for the task (I've heard 1/32" is the best tip size to use?). Any ideas on an inexpensive soldering iron that comes ready with a small tip for soldering SM ICs? I don't anticipate using it too much.
http://forums.parallax.com/showthread.php?129170-Build-Your-Own-SMD-Microscope&p=972302#post972302
Build Your Own SMD Microscope
By Humanoido in forum Projects
Build a Simple DIY SMD Microscope
Now Upgraded with BASIC Stamps
and servo motors!
Add BASIC Stamps & Servos to Your SMD Microscope
Combine two projects for more functions
Reserved for Microscopy Image Samples
Posing some sample images
Getting the Maximum Out of Your DIY SMD Imager
You can squeeze more information out of your DIY
SMD Imager by following a few good tips.
SMD Microscope Application
Work those Penguin Boards!
Either the Med-scope type or that Mantis Elite look like the ultimate solution, but definitely out of the price range. The USB scopes could be useful, but as was pointed out, the magnification is pretty high. I was actually tempted to go with one of those head mounted goggle-type magnifiers, but I think I would find them too annoying to wear.
I do have concerns about the mount, but none of the reverse mounted scopes I could find were in my price range. Also, the cheaper ones all seemed to have reduced working distance. I guess if it turns out to be a real problem I'll just pack it up and sell it on eBay, or hack it apart and build my own mount
@JeremyJ
Check out this video on YouTube: Professional SMT Hand Soldering
That kind of beveled tip works well. It's small but can hold some solder at the very tip which pointed types won't do very well. Plato makes a very similar tip that you can find at Mouser and other places. For the iron itself, just look for a low-cost Hakko knock-off.
