programming
Hi guys,well iv got a boe bot and am loving it again thanks to some input from another post,but one day i want to move up to something more advanced eg stingray , which means more complicated programming ,so in your opinions what programming language should i choose.and if possible some resources would be nice.thank you
Once you're ready to learn another programming language and microcontroller, you could replace your Stamp with a SpinStamp and start with BoeBoeBasic which supports the BoeBot itself and the PING))). BoeBotBasic can be configured to use an xBee wireless link for its "console". You could even attach an SD card socket to the SpinStamp and store Basic programs and data on PC-compatible files. When you're ready, you could also program in C using Catalina. There are other choices as well including Forth, Propeller assembly language, PropBasic, etc.
If you decide to use a SpinStamp, remember that it (and the Propeller in general) operates using 3.3V logic voltages rather than the 5V logic of the Stamps. Since the BoeBot operates with 5V, you'll need to use 2.2K resistors between the SpinStamp's I/O pins and the various sensors and servo motor control signals. That's how BoeBotBasic was originally developed.
