What is the opposite of an 74HC165?
MJHanagan
Hi everyone - I am using a 74HC165 IC to read a set of 8 parallel inputs and send the result in a serial data transfer. I am now looking for the IC device that does the opposite (serial in parallel out). There is a 74HC164 that looks like its would do just this but looking at the data sheet it seems to indicate the input bits are posted to the LSB then sequentially marched towards the MSB position. I need to read all 8 bits into something like a shift register then after all 8 bits are in the entire set gets transferred to the outputs. Am I reading the data sheet right? If so is there another device that can shift the bits to the output all at once so I don't get momentary on/off signals at the outputs as the data gets transferred in?
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/74HC/List/0/SortField/4/ProductID/229/Default.aspx
Data Sheet Here
You would keep OE high until you had all bits loaded. The nothing should show on the output until OE went Low.
Data Sheet Here
The MCP23016 and MCP23017 are I2C devices - the MCP23S17 is a SPI device.
