Questions about Catalina and Codeblocks 10.05 — Parallax Forums
KMyersKMyers Posts: 433
edited 2011-09-24 09:12 in Propeller 1
Hi and thanks for reading. I recently installed the new Catalina and Codeblocks 10.05 with issues. I have installed and re-installed several times. In following "Getting Started with Codeblocks" everything is OK until I install the Codeblocks compiler with the one with Catalina in get a compiler already defined (see attachment). Catalina is already listed in the compilers setting which I set as default.
When I make a new project Catalina does not show up but is listed as a User Template. Can someone tell me what I am missing or doing wrong?
Thanks in advance..
  • RossHRossH Posts: 5,738
    edited 2011-09-23 20:39
    Hi Ken,
    Sorry - I missed this post. I presume you got this sorted - if not, just download the latest release of Catalina (3.2) - all this stuff is now set up for you automatically - you no longer need to install the compiler plugin manually.
    Ross.
  • KMyersKMyers Posts: 433
    Thanks Ross did get it working my error! Even making some good headway in C. I for one love Catalina and am still reading and playing!!
