video question for hydra system
Last night I got my Hydra out again and started looking for a 8x8 tile driver...I started looking at the Dr Hydra's TV driver. In the past I have used an older tv and the display was rock solid...however, last night I was using a newer flat screen tv and the image/game bounced up and down. It looked like each refresh was one line off causing the screen to flicker...more of an even/odd line change...has anyone else seen this...and if so, is there a way to fix it
Dave
I got it fixed...last weekend I am was able to determine the problem was related to too many vert lines and an extra half line (thank you ericball)...it turns out the new LCD tv has more stingy timing specs...
