Oscilliscope Recommendations?
I unfortunately have a Tek TDS 220 which claims 100 MHz but fails to deliver it effectively. Apparently one needs a multiple of that rating to show Propeller signals. Phil-Pi's waveform display posts are excellent but his scope is no longer manufactured.
What is your recommendation for a good cheap scope suitable for 100 MHz Props or more? I'm open to any manufacturer, even a PC add-on.
BTW, if you can get a new shaft and disassemble the scope to replace it, there's a chassis ground wire that has to be unsoldered just to get the case apart.
I looked up the serial numbers but mine is outside the recall range. Thanks.
