How could I get Information from an unknown Compass Model
This is the Compass Picture
But I can't find it's spec...
The compass module has the following main chip used:
WT50F5, HMC1022, MCP6021
How can I solve the sensor signal?
I found datasheets for all three devices.
It probably runs on its own and sends data to an LCD (not included.)
There are only those 8 pins.
Perhaps by spending some quality time with those datasheets and Mr. Ohmmeter you could trace out which are +V and GND and the LCD pins.
So I can't get the value without LCD. Right?
The assembly has 8 pins, 2 must be for power, so maybe 6 are for LCD data (segments). Maybe it shows N, S, E, W or... maybe it uses segments to "point" to a compass heading on a bezel.
If you can pin out the power pins (they may trace back to the op-amp), applying 3-5V might get it to start knocking out "data".
