Propeller timing issue — Parallax Forums
FriedVFriedV Posts: 77
edited 2011-09-14 12:41 in Propeller 1
Hi,
as I am not able to get a 6,25 Mhz Xtal, I tried to work with a 25 Mhz oscillator (Valvo X05860, 25Mhz),
but without succes.
I have attached 3 screens, 1. Oscilloscope trace of clock signal, 2. Spin code, 3. LSA Diagram.
What am I missing?
    To use any of the PLL modes, your crystal or XIN frequency has to be between 4 MHz and 8 MHz, according to the datasheet, although 10 MHz works fine, too. 25 MHz is way out of range, though, and the PLL will not be able to lock.
