Why "rectangulars" in HTML instead of characters?
Quite rare, but now and then I see those double-decker 'rectangulars' when browsing the web.
Is there a way to avoid that 'art' and see what's behind it in Latin alphabet?
John
John
The most likely cause is a missing font on your system.
Do you have a link to that page?
http://en.wikipedia.org/wiki/Specials_%28Unicode_block%29
I've seen the google translator botch the ASCII code.
And some times I've seen this when converting Unicode to ASCII and vise versa.
Like Luis said above.
Check your font files.
Mr Comb brings up a good point.
http:/html:, does not use error checking.
This is a need for speed protocol,And if there was an error ,The protocol would just let the error fly.
Hope this helps
Here http://www.swarthmore.edu/NatSci/echeeve1/Ref/Fourier/FourierBio.html
As wikipedia points out "...U+FFFD � replacement character used to replace an unknown or unprintable character..."
"...Check your font files " - where and how ?
Which fonts is my pc missing - as obviously it is :-)
HTML source.
I see that the browser is using UTF-8, but the encoding is windows-1252, so I selected that encoding in my browser and now the text appears correctly.
John
So - is there a way to make Western (Windows-152) a sticky instead ?
https://bugzilla.mozilla.org/show_bug.cgi?id=158285
"You can't. Firefox will switch the encoding to the value send by a web server in the HTTP response headers..."
Oh well, I'm not going to spend any more time trying to make it 'think' otherwise ...
