[puzzle] waitcnt, is the destination/source field read before or after the wait?
tonyp12
Waitcnt is a read-modify-write instruction, just like Add is.
So you could say that it's just an Add that freezes midway.
After the required wait, the source fields value is added to the destination fields value
So internally it will do a read dest, add source, write dest.
Prove that the destination fields value is read before the wait or at time of exit.
Once by the cogs wait and cmp routine that halts pc
And then on exit its run as regular Add from scratch. (that for some reason it saved ic curcuit estate to do so)
Question:
By putting phsx in dest field with its pseudo shadow properties could you prove or disprove that?
What other ways could you use to prove/disprove that's the case.
Or you could change the puzzle to when is scr read (much simpler)
Is waitcnt just an Add that freezes midway at one of the two choices below:
dest , source, (wait) ,dest
dest , (wait), source ,dest
Besides, why would the operand fetch behaviour be different for wait* instructions? Even a nop follows the src/dst/live src pattern.
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 PUB start cognew(@tester, 0) DAT org 0 tester mov dira,#3 loop mov outa,cnt add outa,#32 andn outa,#1 or outa,#2 waitcnt outa,#1 andn outa,#2 jmp #loopChannel1 is outa[0]; channel 2, outa[1].
