Looking for recommendation on 7"-12" composite monitor 12V for use with Propeller
RobotWorkshop
I'm looking to get a new monitor for my robot and want to switch from the old 640x480 VGA to a composite monitor. It seems that there are more video options if I switch to composite and I can free up a few more I/O pins. So if you are using one that works well or know of any current deals please let me know. The requirements are:
- 7" to 12" LCD screen
- 12V DC power
- Composite Video input
- Mounting holes on rear for standard wall mount brackets
If the monitor also has a regular VGA input as well that would be great but it isn't required.
I'd like something fairly recent so I can get more than one of the same model if it works out.
Robert
- 12V DC power
Robert
I have a range of these in different sizes and they work well on the prop. Only 3 pins and 3 resistors which is less than VGA.
Smaller ones are cheaper and use less power.
The mask is set to FF for all the usual 8 pin use but setting it to 0F (or 07) gave H & V + 2/1 forgrounds from the usual BLUE bits. I an sure that this kludge is extremely wasteful on memory though, but that could be got around I am sure.
There are loads of 7"+ monitors around from reversing cameras and in car DVD for the kids. At least they are LCDs, I had to chuck out my last CRT 10" as its focus was gone (bit like me).
'implant pin settings and pointers, then launch COG
reg_vcfg := $200000FF + (BasePin & %111000) << 6
i := $FF << (BasePin & %011000) <---- This is the mask part I modified
j := BasePin & %100000 == 0
reg_dira := i & j
reg_dirb := i & !j
longmove(@color_base, @ColorPtr, 2)
if (cog := cognew(@init, SyncPtr) + 1)
return true
Alan
http://www.ebay.com/itm/7-TFT-LCD-Color-Screen-Car-Monitor-rearview-camera-VCR-/150591261270?pt=LH_DefaultDomain_0&hash=item230ff04a56
http://www.ebay.com/itm/Car-7-TFT-LCD-Color-Monitor-Backup-Camera-CZ16-/220818657670?pt=LH_DefaultDomain_0&hash=item3369d15186
http://www.ebay.com/itm/Digital-Prism-ATSC-710-7-480i-HDTV-LCD-Television-Bundle-5-100-/110741044871?pt=Televisions&hash=item19c8ae3e87 (with tv tuner, USA)
http://www.ebay.com/itm/9-Car-Standalone-Headrest-TFT-LCD-Monitor-2-Video-input-16-9-Display-Mode-/110742144799?pt=LH_DefaultDomain_0&hash=item19c8bf071f
1. DVD headrest display. Amazon generally has some 7" units under $100.
2. Actual portable DVD player with video input. Generally the cheap 7" units don't have video in, though; you have to go to the 8 or 9 inch units that are $150+
3. Portable DVD player as in #2 which has broken so that it will no longer play DVD's but will still play video in; these used to be very cheap on eBay but people have wised up about their use for monitors. You might be able to scare one up among your acquaintances though.
Thanks for all the suggestions. I am down to two choices that look good:
- Haier HLTD7 7-Inch Handheld HDTV with Built-In DVD Player (around $75 through Amazon)
- Haier HLT71 7-Inch Handheld LCD TV (around $50 through Amazon)
I'm leaning toward just the plain LCD since I don't really need the DVD playback on my project and mounting the DVD version may be a bit more difficult since it doesn't have a standard mount in the back. The regular LCD TV is supposed to use a standard 1/4 mounting stud. I'll find out for sure soon.
Robert
http://www.parallax.com/Store/Accessories/Displays/tabid/159/CategoryID/34/List/0/SortField/0/Level/a/ProductID/337/Default.aspx
That is definitely one to consider.
The PL7003 has 300:1 contrast ratio for black/white/color richness and runs on 240mA max. 12ms response time is all they lay claim to.
Ebay units are 100:1 and some are running on near 1A. 10-30ms response time depending on black to white or white to black transition.
Life span? Who knows.
Oh, and the nicest feature was a built in battery. That comes in handy in case of power outages, or if you have to temporarily move a project.
