BS2 carrier board help
Hi
i was hoping someone could point out the difference between the Vss/Vdd bus bars on the BoE Dev board and pins Vss/Vdd on the carrier board. As i have a serial display and an airtronics reciever connected on the BoE board and all works great, using the bus bars. i move the same circuit to the carrier board, soldering the power wires together then the same with the ground wires and both to a servo connecter and slip that onto the carrier board pins, and chop the middle wire that would goto reset. no worky worky.
i can produce the schematic and pics and all if needed, but was hoping it was sumthin obvious.
thanks in advance
Chris
thanks in advance
Chris
Dave
so now i have rewired the carrier board and have moved to 5v reg to provide power to everything including the carrier board
1 amp 5v reg so should be plenty
so here is my new question
if i have connected the ground (-) port of the "9 volt plug" on the carrier board to the common ground
will that be good enough or will i also have to connect pin Vss to the common ground
considering the motor controllers i am driving need to be connected to the ground of the device that is driving them
so the motor controller grounds goto the common ground
so i guess the real question is...
is the Vss pin the same thing as the (-) port on the 9 volt connector?
how about this one...
i am using a 5v regulator to power the carrier board, a 4x16 serial display and an airtronics reciever
i am driving two sabertooth motor controllers with the stamp and i have connected the ground from the motor controllers to the ground on the 5v reg
i connected a 9 volt plug to the 5v+ and the ground and connected it to the carrier board
the idea is to connect the ground of the motor controllers to the ground of the stamp
or do i also need to connect a vss pin to this common ground
a handy bit of info is that the voltage regulatot gets REAL hot
have i miswired? or is that common
maybe to many amps?....but i doubt it
anyway my motor controllers are freaking out
they listen somewhat but do random things while in the middle of doing what i told it
everything was workig great then i moved to power from regulator and this!
help! i am salty at it now
chris
You don't want the common ground to be on the carrier board. You want it to be at the battery or at the motor controller so the heavy currents stay within the battery and motor controller. You then have a Vss (ground) and Vin (unregulated + supply) lead from the battery or motor controller board to the BS2 carrier board. If the regulator is getting hot, you've either wired things incorrectly or you have too much current drain from the regulator. The Stamp and the serial display won't draw much. I have no idea what the receiver draws. You should know that.
Some of the sabertooth controllers will put out regulated +5V for use by a microcontroller. Will yours do that?
A schematic will help a lot. Do you have enough bypass / filter capacitors in the right places? Have you wired the regulator properly? There's a lot of crucial stuff you're not telling us.
i have two 2x25 sabertooths
http://dimensionengineering.com/Sabertooth2X25.htm
they will produce 5v but if i run the stamp off of that then the motor controllers have power before the stamp boots up and freak out for 1 second or so
therefore i would prefer to keep the bs2 power off of the controllers so in the future i will add a switch that turns on power to the controllers after the stamp is booted up
i have no filters or caps to speak of
it worked perfectly using the board of education carrier board
then i moved to the carrier board and needed to add the 5v reg because of amps from the vdd pin were too high
here is a copy of my schematic.....sorry its kinda sloppy
maybe i could move the 5v ground of the controllers off of the regulator ground and onto the Vss pin on the bs2?
im at a loss but i feel certain the issue is somewhere in the 5v reg or ground
like i said it gets real hot like burn u hot
thanks for the reply Mike
Chris
You do need some bypass capacitors on the input to the regulator and on the output of the regulator. The specific values depend on which regulator you're using. If it's an LM7805, you need a 0.33uF 50V ceramic capacitor on the input of the regulator and both a 0.1uF 50V ceramic capacitor and a 10uF 10V electrolytic capacitor in parallel on the output of the regulator. The capacitors should be mounted within 2 inches of the regulator.
do you have a idea on how to integrate a heat sink
and what do those caps do and where can i get them
or better yet is there a better way altogether?
a dc/dc converter can bring me down to 12v then a 5v reg?
i am going to need 12v anyway i was just gonna add a 12v reg
any other ideas?
thanks
chris
Dimension Engineering makes adjustable regulators as well that can produce 12V. You need to know how much current will be drawn at 12V. They make a 1A and a 3A regulator. You'll need to use the appropriate one.
There's likely to be a RadioShack store near you. Go look in their parts area for heatsinks. They have several different kinds. Usually the more fins and the larger the mass of metal, the more heat it can dissipate. You'll also need what's called heatsink compound which they also carry. Read the Wikipedia article on heatsinks for more information and follow the links provided to learn more. RadioShack would also have the capacitors.
i will check the manual
Because the tab of the regulator package is connected to ground, it's pretty easy to attach a heatsink to an LM78xx. Use a thin layer of heatsink compound / grease between the tab and the heatsink and hand tighten (tightly) the screw that holds the regulator to the heatsink.
just wanted to verify that i need the .33uF cap specifically for the input side
being as radio shack had what seemed to be every cap known to man but that one
they had .22 or 330 or 3300 but no .33
and i was able to get everything else there
thanks
chris
Mike has recommended the Dimension Engineering regulators several times here on the forum. I frequently second his suggestion. I've recently had trouble with interference when using Dimension Engineering's switching regulators with wireless projects.
I don't think there is problem with DE's regulators specifically; the problem is inherent with switching regulators in general.
One of the projects I've had trouble with was using a Spektrum 2.4GHz helicopter radio. The transmitter and receiver frequently failed to lock on to each other when I used a switching regulator. Other regulators didn't cause this problem. The other project where I think interference from the switching regulator was an issue was a GPS data logging project. The regulator limited the GPS units ability to receive the signals from the GPS satellites.
I just thought I'd add a warning about this for those who might be considering a switching regulator.
Duane
Thanks for the suggestions. I'll give them a try. I would be very useful to be able to use these switching regulators with the projects I mentioned. They are both battery powered and the switching regulators would really help with battery life.
Duane
i added the heat sink, but that didnt help
so i am trying to find all of the caps to add them to my existing regulator
if that doesnt work, i am moving to a dc/dc converter to 12 volts then a 5v switching reg and i will try to shield it like mike says
hopefully that will work
what do you guys think of a chassis ground?
