ITeadstudio ITDB02-3.2WC 3.2'' TFT LCD — Parallax Forums
megaionstormmegaionstorm Posts: 178
edited 2011-09-08 17:43 in Propeller 1
Is there a p8x32a program for a ITeadstudio ITDB02-3.2WC 3.2'' TFT LCD ?
  • mynet43mynet43 Posts: 644
    edited 2011-09-08 15:15
    You might be able to modify Rayman's driver. He supports the ILI9325 driver chip. Yours uses the ILI9327.
    I just wrote a driver for the ILI9340. So you could check to see which command set is closer to the one you're looking for.
    Let me know if I can help.
    Jim
  • megaionstormmegaionstorm Posts: 178
    edited 2011-09-08 15:38
    Can't find the driver from rayman !
    edited 2011-09-08 15:48
    Sorry, you will have to check with Rayman. He has his driver copyrighted and has not put it in the OBEX.
    Jim
  • RaymanRayman Posts: 16,276
    edited 2011-09-08 16:03
    I believe Jim is talking about my "PSM" drivers... I think they're still posted on my website somewhere...
    BTW: PSM is discontiniued, but I'm working on PSM2 already...
    edited 2011-09-08 17:00
    Rayman wrote: »
    No !
    Found it:
    http://www.rayslogic.com/Propeller/Products/PSM/PSM.htm
    Look under "file downloads" for the drivers...
