Moving Parallax FONT to an Macintosh iMac
Is there any info on getting the Parallax font in an iMac to preserve a 'drawing' in a Spin file, when copy/pasted into the forum, so that it will retain its formatting.
I just created a 'drawing' and what a mess. On selecting font size and type I noticed that Parallax font was missing on the iMac. That is probably why I never could create such a drawing.
Like where to find the font file(s)? I am running Windows under Parallels virtual engine. And I'm rather lost working with Windows when I have to do such a task.
Thanks for any help on this matter.
edit: I was able to find the fonts on the Windows side, but Copy/Paste doesn't seem to work to do what I want. Must be some other 'windows' trick.
Thanks for the suggestion, BST couldn't provide anything beyond what the iMac has in its fonts. Unfortunately.
I can see the Windows Parallax font, but cannot move, copy, or do anything with it in the Windows environment. I can try to click/drag to a iMac folder but then get this error message:
.....The operation cant be completed because you dont have permission to modify some items.
Rather misleading statement as I was just trying to move a new item into the fonts folder. Guess I need to find out the meaning of that error message. Always seems one runs into NEW things which are not obvious.
I use bst on a macbook OS10.6.7 and can see the fonts fine.
Found Font Book which helped me move the Parallax font into the Font folder, after I moved the Windows Parallax font icon directly onto the iMac desktop. The font appears in the font folder, but doesn't show up in the Parallax Forum 'font' selection. I'm not using BST much, as often I need tools like ViewPort or PASD which are Window based. Found the 'permission' detail was because I needed to provide a valid password, which needed to be done via Font Book
My goal today was to get the Parallax font to show up in the forum font selector so I could see and edit a 'drawing' there. For some reason formatting seems to get lost if I Copy in Windows and Paste into the iMac Forum.
BST is nice if I don't need those tools, EXCEPT for not being able to print from BST directly. Nice app otherwise.
I finally found a way to move the Parallax font from Windows to the iMac. However, in the Parallax forum on the iMac editing a file, the Parallax font does NOT show up in the Fonts selector in 'Go Advanced. editor.
I find that rather strange. I don't recall ever having Parallel fonts on the iMac side before. Thus could not edit a Spin 'drawing' using Parallax font. Totally near impossible to even format such ddrawing, let alone not being able to display the unusual (lines, Rs, Cs, ground/power symbols, etc.).
I tried to illustrate a simple 'schematic' drawn in Spin; but copy/paste effort doesn't retain spacing due to probably only lack of having the Parallax font. On the forum it looks terrible if working on the forum on the iMac side.
You wrote:
Well, where does one obtain it? I couldn't find it anywhere else.
Even searching for Parallax or TrueType wouldn't find the fiie in the fonts folder, for some reason.
Is there something wrong with the forum? Are my messages getting posted? I uploaded the file you needed. I reminded you in a subsequent message that I had done so. Is there something else I can do to attract your attention?
Don't know why your posts wouldn't retain the file.
The font is used with the PC Propeller Software Tool and also works with BST on a Mac. It won't appear in the edit font list for the Forum postings. It will appear with TextEdit and other word processors. From TextEdit, select Format, Font, Show Fonts, and there you'll see it.
To prove it's working, start up BST, New, and type some comments into the program field. Now go to Tools, Character Chart, and select some of the same characters. You'll see they're identical. So your Parallax font is correctly installed and working on the Mac.
My whole goal was to properly format/edit a Spin 'drawing' in the forum posts on an Mac/iMac. They just don't get copy/pasted correctly and maintain their formatting.
You wrote
and then you write
It may be correctly installed, but not properly working on the Mac when in the Parallax forum edit mode.
Anyone know why it won't work properly? And if it can be fixed? Forum member, Parallax???
This will specify to the user's browser which font to use. It's up to each user, though, to have this font installed on his own machine for the page to render properly. The forum server has no way to include the font in the webpages being served.
Also, if you're posting drawings or indented text in the Parallax font, you have to incorporate them in code tags to keep the spacing accurate. (The font tags have to be inside the code tags for this to work, the size should be set to 2, and boldface should be avoided.) Here's an example:
[font=Parallax][size=2] ┌───── rhipins xhipins ─────┐  ┌─ rfbpin  Audio Inp ──╋─╋─── rcvpin xmtpin ─┳─╋──┳─ Audio Out   │ │ └─── rlopins xlopins ───┘ │  2.2K └───── rlopins xlopins ─────┘ │ xenpin ────────  [/size][/font]
'Hope this helps...
Trying it from MacBook, using size=2 as in your text.
[FONT=Parallax][SIZE=2] 1k p5 ───────┬────┐ 9.1M │  PVDF tab p6 ────────┘  [/SIZE][/FONT]
[FONT=Parallax][SIZE=2] .... cog ctra at Fx .... cog ctrb phase backed up Nx cycles of F comibined by Prop wired OR: ..... output Nx pulses at frequency Fx [/SIZE][/FONT]
Maybe my problem is because the 'drawing' originally was created in Prop Tool on Windows, copied from there and the scrapbook contents pasted into my post on the forum on the iMac. Here's the thread; it is presently on page 2, near the bottom, post #1 of:
[unsolved] Strange QuickStart board and LCD (Wintk WDC2401P - a 24 x 1 line display)
I re-copied the drawing and pasted it in. Looked OK at first but when Previewed, it looses its formatting, some portions moving too far to the right. Maybe it would be OK if I created it on the forum, but it is part of a .spin file.
Weird part is the format looks almost decent in the edit window, but with the R, C, ground symbols missing (well, a faint placeholder symbol there). When you Go Advanced, the formatting is loat, with various parts scattered horizontally on each line. And final drawing on Save, in the post is still improper.
Zterm version 1.2 is available free at http://homepage.mac.com/dalverson/zterm/. It's not cripple ware. However he accepts 'registrations' and donations. I had been using Zterm for 12 years, so I made a donation. I was impressed that he bothered to update 15 year old software.
Thank you for that information on Zterm. I've not used BST enough to know whether is us usable for my use or not. I'd only tried it once using the QuickStart and Jonny Mac's QS demo of the touchpads and LEDs. Guess I should look into Zterm.
Pretty disappointing that the Parallax tool font isn't totally usable on theParallax forum. Maybe it is a Windows vs non-windows systems. However, being TrueFont seems it should work OK. I wouldn't have thought the forum editor to be this 'fussy'.
The weird horizontal spacing is probably due to not using size=2. At least that's what I observed when using the larger sizes.
I just rechecked and it is 2 poioit Parallax. Here's my 'code' line: in bold: [code].
Wish that were the culprit. I'm not sure if I've ever had a Parallax font drawing turn out decent, I'll have to play with it later; else, won't get projects done. But I see nice ones that I assume are Parallax font drawing and they look nice.
For me, a good test was the demo program for the PIR sensor because it has a schematic drawing. If the Parallax font is not active, the drawing will look very strange like this:
