Scribbler Robot Motors Stopped Working
I have a Scribbler Robot (the first one) and the motors stopped working. I tried restoring factory defaults in case I had messed that up but that didn't help. I took it apart and everything looks just fine. I cant even hear the motors trying to run :frown:. Everything else works fine. Any Ideas?
http://forums.parallax.com/showthread.php?133802-Scribbler-Motor
If that doesn't help, you can replace the motors. I had to do that with my Scribbler and I ordered this one: http://www.pololu.com/catalog/product/604. I should have ordered a pair as an old/new motor combination isn't the greatest match.
Edit: Also check the stall sensor status. Is pin 7 high or low when the motors are "on"??
Unplug that motor from the robot and put 3-6 volts on it and see if it turns.
But there are values in the EEPROM which are used to adjust the relative speed of the left and right motors. They are not over-written when you restore the factory program. I wonder if a bad value got stored in the EEPROM if that could confuse the program to not turn the motor.
It's been a while, but I know the GUI lets you upload a calibration program to Scribbler. Does it have a way to clear the EEPROM settings?
Suggest you methodically trace the right motor wires back through all connections and boards to the motor driver circuit. Find the BS2 pinout connection to the right motor (pin12) and see if you get 5V to it when you make it high.
We're offering dealer financing and no-interest loans on the red S2s these days. We even offer protection plans for an extra $25/Scribbler. I think the guys in back have added an undercarriage coating process as an upgrade, too.
Truthfully, let's get you a shiny new S2! From a distance it looks like the forum members have done everything we'd suggest, so there's no point in keeping the patient open on the operating table. In this case it might be best to use it as parts.
Send me an e-mail with your shipping address to kgracey@parallax.com and we'll bring this to a happy ending. As long as you're not expecting overnight shipping to Dunedin, New Zealand we can have this issue closed up today.
Spin is block structured with global and local variables, so it is a more modern language than PBASIC. Once you get comfortable pulling down code from Obex (the link in the navigation above), you can do a lot fast. The only real beef I have with it is >= versus => and lack of types.
Coming through in true Parallax spirit. Everyday, your company does something above and beyond the call to impress me and make me glad I do business with you guys!
He'll set you up with a bright shiny new S2!. Ken has the propensity for doing this every so often - strike while the iron is hot!
-Matt
nice try.
-Matt
I not have any Scribbler.
So it is not only motors that will not work -- It is entire Robot that stopped working
I can see that erco has pulled you over to the "dark side"...resist! again I say, resist!
-Matt
Some times it is next impossible to resist!
