Oscilloscope Probe Adjustment
I have a 10x probe mated to a scope my buddy gave me, and I can't get it adjusted right. You'll see what I mean in the photo. If the (brand new) probe's adjustment screw does't straighten the square wave, should I assume the square wave reference is off? I don't have a spare probe or a spare scope, so I'm in the dark here.
Also, anybody have experience/opinions on these LeCroy scopes?
Thanks.
Thanks.
LeCroy scopes have a good reputation. I've only ever used one of the top end ones, though, where I once worked.
You could check the signal path without the probe by running a wire directly from the scope input over to the calibration lug.
The 9400 seems to be available pretty often on ebay for a good price, and it seems to be very capable. You do have the manual, right? It is available on the LeCroy site. I use the LeCroy 9374L, also purchased used.
