Practical limits on clock generation on 'temporary' circuits
All,
I have a somewhat ambiguous question regarding the ability of the Propeller (or any chip for that matter) to flip an output pin when not in a carefully designed circuit board.
If I am not mistaken, using assembly I should be able to flip a bit up/down with two sequential instructions taking 8 cycles, which at 12.5 nS per cycle yields a period of 100 nS. However, my question is more in what is reasonable in terms of driving parasitic capacitance in the typical experimenter circuits (using hook-up wires, breadboards, thick solder joints etc.) I have build various circuits that have the Prop generate a clock, and have never managed to have them work at more than 200-300 KHz. (i.e., a period of no less than a few microseconds). None of these circuits are on a PCB, instead they are using hookup wires between the Propeller and a breadboard (on a Stingray).
Watching the signal on an oscilloscope, as the frequency increases, I can see it becoming more of a sin wave as opposed to a square wave, but even at early stages of 'roundness' the circuit works, but at some point it doesn't.
I am not sure if the 'roundness' of the waveform is an artifact of the oscilloscope itself, the wires, or for that matter my program. What I know is that various communication protocols that work at lower frequencies, quit working at higher frequencies even though they are within the calculated capabilities of the Prop and the specs of the attached devices.
Is there any quick and dirty estimate on maximum frequency that a functional clock signal can be generated when using hookup wires? By the way, in all cases, the 'load' is another chip/gate/IO pin with pretty high impedance, so I don't think the issue is loading. Any guidance would be appreciated!
The synth object limits the frequency to 128MHz. Of course you'd have to have the appropriate crystal to run at 128MHz. The Prop does not run well at 128MHz without a lot of help (cooling) or limiting cogs/functions.
Duane
This is what the same signal looks like on the same scope with the same hookup, but with the input bandwidth limited to 20 MHz:
You can't see more detail than what your instruments are rated for, even though that detail exists in reality.
I think I need a new scope ...
(A square wave is actually comprised of a sine at the original frequency and lots of lower-amplitude sines at 3x, 5x, 7x and so of the original frequency. )
Also, the max frequency generated in SW without use of counters doesn't always equal two output commands.
(Unless the commands also contains some sort of 'goto' in the second operation. Yeah, we're lucky with the Propeller. ;-)
