HID MiniProx RFID card reader help please
                    Hello all, I have been lurking and reading for awhile, and I am comparatively new to the Propeller. I am stuck on figuring out a suitable course of action regarding reading these 125KHz RFID passcards.
I have a HID brand MiniProx reader that outputs a protocol called Weigand, but there is a daughterboard that converts the Weigand format to a clocked-type of bitstream, and I am having difficulty figuring out how to proceed.
I need to be clear, I have been wrestling with this for quite awhile, and I absolutely am not asking anybody here to write my code for me.
I am a decent at PBasic, PIC Basic PRO, Motorola assembly, BasicX, and a couple others that escape me right now. I need a couple promotions to be considered a novice with Spin, and I am definitely wrestling with Propeller Assembly for now. I have RTFM, and I have purchased a couple Propeller books, one of which is "The Official Guide", so I have no problem doing my homework.
With that out of the way, I am trying to build a standalone controller for these cards that has a power supply, the reader, the daughterboard, and a serial LCD. The reason for the project is because the inkjet ID number wears off of the cards after awhile, and I am looking for a way to extract the ID without scanning the card at the fuel pumps, so that I can engrave them onto the cards.
There are two lines from the daughterboard that I need to decode; a clock, and a data. These two lines idle at +5 volts all day long until a card is scanned. When a card is successfully scanned, the reader beeps and begins pulsing the clock line low for approximately 300 microseconds, with a period of 2 milliseconds per bit. When the clock line pulses low, if the data line is low, that is a 0, and if the data line is high, that is a 1. From my reading, there are 26 bits that arrive from the controller- I can parse the bitstream myself, but I am having trouble setting up the propeller to be waiting for the first bit, and collecting the required number of bits.
After a successful read, the controller will output to the LCD the required information for a few seconds, then clear the screen and start over waiting for another card. I can write to the LCD with no problems, and have created an object with the LCD constants pre-declared.
I have tried "waitpeq", "waitpne", "if" and some other different attempts, but I can't get it to capture a bit, shift it into my variable, and capture the successive bits- it always hangs, and I am not good enough yet to figure out why. I plan on buying Viewport within the next few days but I am waiting on a check that hasn't arrived yet.
So there it is in a (lengthy) nutshell: wait all day for the clock to start pulsing, when it does, count off 26 bits and shift the level of the data line into a variable. It seems easy, and yet I can't figure out how to do it. The low pulses of the clock (and data when it is 0) are kind of quick, but it seems to me that a period of 2 mS is plenty of time to shift the bit in and rearm itself.
Without writing my code (unless you really want to, of course) can somebody maybe offer up some advice on a basic strategy for me? I can't express how much I would appreciate any help.
If I didn't explain it well enough, please let me know.
Thanks big.
-bryan
Thanks big.
-bryan
You could also do this with a Propeller. "WAITPEQ(0,|<clockIn,0)" will wait for the I/O pin to go low. You can then read the data bit ("myData |= (ina[dataIn]<<i") and wait for the I/O pin to go high with "WAITPNE(0,|<clockIn,0)". "i" is the bit number starting at 25 and going down to 0.
It's neat that you are in Minneapolis, I live in Maple Grove. I appreciate your prompt reply. I have tried some variation of what you suggested, to no avail. I will revisit my prior attempts and compare my code to your suggestion, to see if I got hung up on something that should be obvious (which is likely).
Logically, I think I have been on the right track, procedurally, though...
I will post my results after I experiment further.
Again, thank you.
-bry
-bry
If you decide to use the clock and data lines from the daughterboard you might want to download some the I2C objects from the OBEX and take a look at them. The output sounds very much like I2C.
I too thought that this was a bastardization of I2C, and I spent a considerable amount of time pursuing that avenue. The problem I ran into there is a) it is quite slow for I2C, and b) the clock comes from the reader and not the propeller.
I am sure hoping that there is a compelling reason for the manufacturer to make this so difficult, and I am inclined to think it has something to do with security- it is an access controller, after all. It would sure be nice if they would have a jumper to output an asynchronous data word for neophytes like me, or even better, true I2C.
Thanks for replying, though, I do appreciate you taking the time.
-bry
I just saw your post. Im currently doing a lot with the propeller and wiegand. They also helped me to start with it (thanks to other members of this forum). Now it is pretty simple to read wiegand with a propeller. With some resistors and some code you can read any bit stream of wiegand. Im currently doing a project for 38 bit but I already did some in 80 Bit also.
This is a snippet of the code to read. (complete code I can not post because it is owned by the end user)
State := %11<< 16
Repeat
Cardnumber[0] := 0
Cardnumber[1] := 0
Bits := 0
Repeat
Waitpne(state,state,0)
Read := ina[D0..D1]
Cardnumber[0] <<= 1
Cardnumber[0] |= ((cardbumber[1] & (%1<<31))>>31)
Cardnumber[1] <<= 1
If read == %01
Cardnumber[1] |= %1
Waitpeq(state,state,0)
Bits++
Until Bits == 37
(I typed this code by head because I do not have the spin file with me now. So dont kill me for a fault. It gives you a hind for the way to do) Im travelling now. If I get home I can send you the spin code exactly.
This is the part that reads the bitstream into two long variables. I use it also with HID readers. I also have a part of the code that generates wiegand. There are currently 50 readers running on the propeller without any problems.
Hope this helps a bit in your search
stef
