Tolerances in the Capacitors for Voltage Regulator Circuits
I'm a hobbyist and often need voltage regulator circuits which require a capacitor before and after the regulator. I am wondering how much leeway I have with capacitor specifications for regulator circuits between 3.3 to 12 volts. The reason I ask is that Radio Shack often has regulators, but not the capacitor with the required specifications. While you can mail order, the shipping charges or minimum order size can be prohibitive for one or two parts.
Can I substitute a capacitor with the same capacitance, but a higher voltage rating for one with a lower rating?
Can I substitute a capacitor with a higher capacitance for a lower one (e.g. 100 uF for 47 uF)?
Sometimes, with the same caveats as above. You really have to look at the regulator's datasheet to see what the capacitor requirements are and then follow them to a "T". Also be aware of the capacitance tolerances, sometimes as bad as -20% to +80%, and design for the worst case.
So it seems that it is always best to read the particular components PDF and not just think that a larger capacitor with improve performance. Also note where and why protective diodes are mentioned.
Personally, if I am going to use a linear regulator, I try to find one that has all the neat features - outputs 1 amp or more, thermal shutdown, shortage protection, reverse polarity input protection, and low drop out voltage. The LM2940 regulator series seems to be a good choice -- but read the PDF for capacitance requirements and compare it to the 78xx series, very different.
