SD Card Preventing Propeller from Booting
If I have a microSD card wired to the Propeller starting at pin 1 (not 0--haven't tested that), the Propeller appears not to boot. I can flash RAM and EEPROM just fine, but my program, which normally outputs data to a serial terminal, leaves my screen blank. The moment I remove the SD card and reboot, things go back to normal. Any ideas?
If I simply remove power to the microSD card and leave all the other pins connected, the Propeller boots fine.
If I insert the microSD card during runtime, the Propeller freezes execution.
prevent the prop from booting.
Can you tell us more? It would be a very unusual problem if removing an extra capacitor fixed it.
Usually extra capacitors help, rather than hurt.
Your problem might be some edge condition somewhere and there may be many small changes
that "fix" it---none of which actually are the real solution.
What type and size was the capacitor, and what was it connected to?
