Need to 'update' all 8-bits at nearly the same time...
I converted two old Lite Brights with a bunch of LEDs to spell out "Shine Your" and on the other "Light." For use at an upcomming David Crowder concert! Anyhows...
Each letter is made up of 15-25 LED's wired in parallel, with a common anode so I can control each letter indivisualy useing my BS2 through a ULN2803A!
Works flawlessly!!! But the way I'm programming it right now is SUPER lame and seems bulky... To create animations I'm seriusly setting here typeing out a bunch of HIGH's, PAUSE's and LOWs... I remeber seeing something before where you simply call a comand and list a bunch of bytes! So for examply... "(????) 11100101" would turn on pins 0, 2, 5, 6, 7, and 1, 3, 4 would be low.
I think this may have been in my C programming class at Purdue... So maybe PBASIC can't do it... But I was wondering what the best way to make animations would be!?! Right now I'm just working on the one that says "Light" becuase it only has 5 letters.... "Shine Your" is JUST over my 8 pins...
May have to do some experimenting with them 595's or just through in another stamp.... IDK... I have both here as an opton...
DIR changes the I/O status (making a pin an input or an output)
OUT changes the output status (HI or LO)
