I need your help. Simple Single Servo Robot
I've got some more goodies cooking on the back burner and could use some help.
I'm looking for some ideas for a single servo robot. Something reasonable simple that doesn't require too much engineering or additional materials.
An example would be the paper, puppet mouth that was on Hackaday a while back.
You guys got an ideas?
Jeff
Jeff
Let's get a contest going, Parallax can make the winner!
http://nutsvolts.texterity.com/nutsvolts/200807/?pg=84#pg82
Since I know that you are very much into the retro designs, how about a 2011 version of the Mattel Vertibird we all loved playing with as a kid, where the SERVO is directing the direction of the helicopter blades?
Genius! I'm mad I didn't think of it...
It's likely to get stepped on (squished) ... Have you ever picked servo out of your shoe? ... I don't imagine it would be pretty.
If we can't get a (kinda sorta) biped robot to just walk & turn fairly well with 1 servo, then we suck.
Not sure if this would qualify (since it has a regular DC motor as well as a servo, but it does have only one servo), but take a look at W. Grey Walter's Turtle (http://www.extremenxt.com/walter.htm). You could emulate one of these pretty easily with a single servo and one DC motor in a tricycle format.
The article says that he used a two-vacuum tube computer, but I believe that it was really just an op-amp (think Solarbotic's Herbie - http://www.solarbotics.com/products/k_hm/). A Prop would be able to blow that away - with seven cogs tied behind it's back
Walter's Turtle used the "front" wheel as the drive, and steering, wheel and the two "rear" wheels as free-wheeling stabilizers; I would recommend using the servo to turn the front free-wheel for steering and the DC motor to drive the rear wheels.
Also, as Beau pointed out, you do like your retro stuff; and this is pretty retro (over 50 years), so this should be right up your alley.
