Meet Wizard - a RoboProp on a $30 chassis
Update: I have made some changes to this package, including its name.
Wizard is a robot I am working on based on the Magician chassis that I now sell. The attached photo shows a RoboProp on a Magician chassis, with an optional standard servo holding a pan head and SeedStudio ultrasonic distance sensor.
NOTE: Panning sensor head, servo and ultrasonic sensor NOT included in prices below.
RoboProp DC Motor Edition Kit $99.95
Magician Chassis with two gear motors and wheels $29.95
SirMorph 5Pack $19.95
Forum Bundle price: $139.95 (Regular price $149.85)
Looks great, Bill ! Nice forum discount. And be sure to charge extra for non-Parallax processors!
LOL... no engraving, I am trying to keep the prices low :-)
I'll be interested in the $30 chassis...
PM me your address so I can figure out how much the shipping would be to your location.
Bill
I am having a blast with robotics... as you may have noticed
I assembled it and mounted three SirMorphs in the front. I plan to use a SN75441 for the motors, just need to look up the specifications to see if this chip can handle it... ;-)
Looking forward to play around with it...
Bill is using the L298 on his board and you are using the SN75441. Both h-bridge chips seem to both in common usage, but is there any reason to use one over the other?
I know the SN75441 has built in diodes, and I've seen people wire two in parallel for greater current handling. But given the extra fiddling the L298 requires there must be a reason people like to use it too.
Are you shipping from the U.S.?
Thanks for posting your progress! Please keep us updated :-)
Nice pics btw!
Here are the specs I have on the motors:
4.5VDC, 190mA (no load), 250mA (max), 0.8kg/cm torque, 90rpm +/- 10% unloaded
SN75441 is rated to 1A I belive, so it should easily handle the motor!
Thanks!
I tried to make SirMorph very versatile. In the October Servo you will see they also work well as line sensors.
The SN75440/SN75441 are nice 16 bit DIP packages, much easier to work with than the POWERDIP15 of the L298's. They are cheaper too :-)
I am using the SN75440 on some unannounced future products (I am currently testing one of those products)
Due to additional consulting work (on GCC for Parallax) I have less time to work on my products - including making web pages and data sheets.
Magician rough dimensions are:
6 7/8" body longest dimension
4 5/16" body width
5 1/8" width including wheels
2 7/8" high from top of deck to surface it is standing on
two decks as you can see :-)
Hopefully I should get some time this weekend to work on the robot, I think I have an ADC chip somewhere to get analog readings from the SirMorphs as well.
Looking forward to the October Issue, maybe I can get some line following going on my robot as well... ;-)
Let me know if you run into any issues.. it should work just fine!
I have used SN75440's before without issues.
As far as line following - I don't want to post the code until the issue is out (less than two weeks) but I could email it to you if you like...
I suggest you add an MCP3208 to your ProtoBoard; that is the ADC I generally use, and it works quite well with RoboProp. Drive the SirMorph's with 40mA from a prop pin, and measure the analog output.
Please keep us up to date with your progress!
The SN754410 works great, I added a couple of beefy caps (1000 uF) to the power supplies (battery and main 3.3V) and put by-pass caps directly on the motors.
To read the SirMorphs, I use a MCP3008 which works really well, it measures the three SirMorphs in the front and the battery voltage...
I will start a new thread and post pictures etc...
Looking forward to it!
I always wondered what your mind would conceive for a prop bot robot and Scooter "RoboProp" has one of the most unique mounting solutions I've ever seen in a robot. The top mounting plate accommodates nearly every possible configuration! Congratulations on this well though-out design!
I really enjoyed designing RoboProp, and as usual Sapieha's layout is a work of art...
I can't take credit for the Magician chassis, as I did not design it... but I decided to stock it after I found it :-)
The new name for the combination of RoboProp and a Magician chassis will be "Wizard"
I will use the "Scooter" name for a non-RoboProp based robot kit.
Good stuff Bill.
-Tommy
