Meet Wizard - a RoboProp on a $30 chassis — Parallax Forums
Bill HenningBill Henning Posts: 6,445
edited 2011-09-24 19:27 in Robotics
Update: I have made some changes to this package, including its name.
Wizard is a robot I am working on based on the Magician chassis that I now sell. The attached photo shows a RoboProp on a Magician chassis, with an optional standard servo holding a pan head and SeedStudio ultrasonic distance sensor.
NOTE: Panning sensor head, servo and ultrasonic sensor NOT included in prices below.
RoboProp DC Motor Edition Kit $99.95
Magician Chassis with two gear motors and wheels $29.95
SirMorph 5Pack $19.95
Forum Bundle price: $139.95 (Regular price $149.85)
    edited 2011-08-29 15:19
    What, no protractor/compass degree chassis engraving? :)
    Looks great, Bill ! Nice forum discount. And be sure to charge extra for non-Parallax processors!
    edited 2011-08-29 15:33
    Thanks Erco!
    LOL... no engraving, I am trying to keep the prices low :-)
  • BamseBamse Posts: 561
    edited 2011-08-29 22:11
    Nice robot...
    I'll be interested in the $30 chassis...
    edited 2011-08-29 22:41
    Thanks!
    PM me your address so I can figure out how much the shipping would be to your location.
    Bill
    edited 2011-08-30 04:10
    Nice Bill. I don't usually troll the robotics forum (lack of time).
    edited 2011-08-30 07:32
    Thank you!
    I am having a blast with robotics... as you may have noticed :)
    Cluso99 wrote: »
    edited 2011-09-15 22:08
    Got my chassis earlier this week and just got a round to play with it...
    I assembled it and mounted three SirMorphs in the front. I plan to use a SN75441 for the motors, just need to look up the specifications to see if this chip can handle it... ;-)
    Looking forward to play around with it...
    1024 x 768 - 113K
    1024 x 768 - 113K
    edited 2011-09-16 06:37
    The SirMorphs look pretty good as bumpers.
    Bill is using the L298 on his board and you are using the SN75441. Both h-bridge chips seem to both in common usage, but is there any reason to use one over the other?
    I know the SN75441 has built in diodes, and I've seen people wire two in parallel for greater current handling. But given the extra fiddling the L298 requires there must be a reason people like to use it too.
    edited 2011-09-16 09:01
    At the risk of sounding like a dullard; I cannot find dimensions or any data for the Magician Chassis on your site. It looks a little bigger in Basme's images than I originally thought.
    Are you shipping from the U.S.?
    Ah, I found the answer to that: British Columbia.
    edited 2011-09-16 10:14
    Bamse wrote: »
    Thanks for posting your progress! Please keep us updated :-)
    Nice pics btw!
    Here are the specs I have on the motors:
    4.5VDC, 190mA (no load), 250mA (max), 0.8kg/cm torque, 90rpm +/- 10% unloaded
    SN75441 is rated to 1A I belive, so it should easily handle the motor!
    edited 2011-09-16 10:17
    Martin_H wrote: »
    Thanks!
    I tried to make SirMorph very versatile. In the October Servo you will see they also work well as line sensors.
    The SN75440/SN75441 are nice 16 bit DIP packages, much easier to work with than the POWERDIP15 of the L298's. They are cheaper too :-)
    I am using the SN75440 on some unannounced future products (I am currently testing one of those products)
    edited 2011-09-16 10:22
    Sorry! You are NOT a dullard! I have just been too busy to post more info. I will try to add product pages to Mikronauts this weekend.
    Due to additional consulting work (on GCC for Parallax) I have less time to work on my products - including making web pages and data sheets.
    Magician rough dimensions are:
    6 7/8" body longest dimension
    4 5/16" body width
    5 1/8" width including wheels
    2 7/8" high from top of deck to surface it is standing on
    two decks as you can see :-)
    Spiral_72 wrote: »
    edited 2011-09-16 13:12
    I choose the SN75441 because I had a few laying around.
    Hopefully I should get some time this weekend to work on the robot, I think I have an ADC chip somewhere to get analog readings from the SirMorphs as well.
    Looking forward to the October Issue, maybe I can get some line following going on my robot as well... ;-)
    edited 2011-09-16 14:17
    Bamse wrote: »
    Let me know if you run into any issues.. it should work just fine!
    I have used SN75440's before without issues.
    As far as line following - I don't want to post the code until the issue is out (less than two weeks) but I could email it to you if you like...
    I suggest you add an MCP3208 to your ProtoBoard; that is the ADC I generally use, and it works quite well with RoboProp. Drive the SirMorph's with 40mA from a prop pin, and measure the analog output.
    Please keep us up to date with your progress!
    edited 2011-09-18 13:08
    Howdy...
    The SN754410 works great, I added a couple of beefy caps (1000 uF) to the power supplies (battery and main 3.3V) and put by-pass caps directly on the motors.
    To read the SirMorphs, I use a MCP3008 which works really well, it measures the three SirMorphs in the front and the battery voltage...
    I will start a new thread and post pictures etc...
    edited 2011-09-18 21:04
    Bamse wrote: »
    Howdy...
    Looking forward to it!
    edited 2011-09-19 02:20
    Bill:
    I always wondered what your mind would conceive for a prop bot robot and Scooter "RoboProp" has one of the most unique mounting solutions I've ever seen in a robot. The top mounting plate accommodates nearly every possible configuration! Congratulations on this well though-out design!
    edited 2011-09-19 08:55
    Thank you Humanoido!
    I really enjoyed designing RoboProp, and as usual Sapieha's layout is a work of art...
    I can't take credit for the Magician chassis, as I did not design it... but I decided to stock it after I found it :-)
    Humanoido wrote: »
    Bill:
    edited 2011-09-22 13:29
    Product Name change...
    The new name for the combination of RoboProp and a Magician chassis will be "Wizard"
    I will use the "Scooter" name for a non-RoboProp based robot kit.
    edited 2011-09-23 07:47
    That is one enchanted robot, In fact, it's magical.. :)
    Good stuff Bill.
    -Tommy
    I love my chassis, perfect size and plenty of holes to bolt things down on. The plastic is easy to drill and no problems with using the Dremel either.
