Wall Charger for BS HomeWork Board
Hi, I bought a Basic Stamp 2 Homework Board Rev E and I have been happy with it so far, but now I would like to also use a wall charger with it, similar to the option with the board of education. I was thinking about getting a 9VDC Wall Wart and directly hooking that up to the 9V batter connection on the homework board. Is this asking for trouble in terms of destroying the micro controller or just not working, or can I proceed according to my plan? Thanks for the help.
Thanks for the help!
2) Yes. Vin is whatever voltage your power supply will furnish.
BUT everything is reversed when you are making a 9V battery eliminator to connect to an existing 9V battery connector. Per Mike, you must test everything with your meter and proceed very cautiously.
